Tamiya TRF415
MS Chassis
Hi
I am going to buy the MSX conversion but I have a standard 415 with the 3mm chassis. So I was also going to buy the MS chassis, will this work with the standard suspension and not the LW suspension? is the 2.5mm chassis with the msx conversion a better car than with the 3mm chassis?
thanks for your help
MSX
Just Finished My MSX !
Originally Posted by AKARA
Got my MSX kit today but no Tshirt. Oh well.
The quality of the MSX kit is absolutely sensational.
Can't wait to try it out !
At last my MSX kit is here. It is all built up now and ready for the indoor season. Hopefully i will get chance to try it in the next few weeks.
just curious, my kit is arriving from speedtech 2morrow, can any one tell me if the body post mount the same or do i have to cut new holes in my new body?
HiH
Ed
Originally Posted by Keith Billanti
IS their anyone stateside beside Speedtech who has them?
//KBpower
//KBpower
www.seattleindoorraceway.com
(425) 251-6119 (i think)
Just a note for you who may have an original 415 and buys an Shooter spool, you need 46mm swing shafts too with the Spool, since it's 6mm 'shorter' than the one-way unit.
Originally Posted by tamiyarcracer
I just called and left a message.. thanks.. any idea what theyre asking for it...
DIBS to everyone else...LOL
Hi there,
I've tested my MSX yesterday and -suprise suprise- nearly the same setup as the old 415. Anyway here's a little sum:
Track: High grip carpet
Tires: CS27, JB Foam blue inserts, Orion Disc wheels hard
Chassis: 3mm
Suspension: Standard
Front suspension blocks: 1A/1A Toe in 0°
Rear suspension blocks: 1X/1C Toe in 2.5°
Suspension spacer F/R: 4mm/0mm
camber F/R: 1.5/2°
Spring F/R: Tamiya white/Tamiya blue
Damper: 3-hole piston 600 Tamiya oil
upper damper mount hole F/R: one in from outside/outside
I ran a yellow stabilizer at the front to make the car more stable into the curves. It feels a little soft on carpet because it flexes more the the 415. Asphalt testing will follow this weekend. :-)
Chassis: 3mm
camber F/R: 1.5/2°
brandbrainz
Isn´t that you Moschy?
Were did you have you´re MSX kit from?
I think they didn´t arrive in Germany yet.
@ V12
Yes, it's me. The kits are still not available from Tamiya germany. But it's useful to know a famous tamiya works rider and to paint for him :-)
OK I know what you mean.
Just wish I also had a MSX.
