Tamiya TRF415
#7636
Originally posted by TryHard
[B]Hi, glad you like it
I think I've actually removed the Carpet base setup from the site now however... whoops.
BUT....the BRM Round 1 setup, is as close as damm it too the base. It used the Lightweight arms, and one-ways. Car deffiently felt very quick with that one on, but recently I've been using a spool, so I've been trying to get a set-up for that.
Your site is very helpful for those of us new to the chassis. The only changes I made were to lay down the front shocks 1 hole on top and I'm using blue assosiated springs in front and silvers in the rear. Also the yellow sway bar in front. This is with the LWR susp. and MS towers on the 3mm chassis. Car has super turn-in and high speed steering. Feels like my 8th scale, just not going 60.
#7637
Originally posted by TRAJ
Nice pics tryhard
I was wondering if poeple have stripped their Screwpins that hold the hub carriers?
Ive stripped my rear one and have no clue how to get it out and replace it.
Any tips?
Nice pics tryhard
Any tips?
#7638
Re: Re: Re: world's kit toe chart
Originally posted by dawgmeat
Thank You, Thank You!!!!!!!
#7639
Nice pics tryhard
Any tips?
Nice pics tryhard
Any tips?
#7640
Hello,
I need some help to understand what is Rebound stroke on the 415 setup sheet.
According to the manual rebound stroke=Droop.
I saw Maezumi's setup on rczone.net. He sets rebound stroke at 3 front and 3 rear. Does it mean that he uses 3mm for droop (with a droop gauge)?
Thanks in advance for your help.
#7641
Originally posted by Hugo
Hello,
Hello,
#7642
Same for me TRF415boy but when you read the manual of the 415 page 21 they explain it in a different way.
So the big question what is 3mm rebound stroke according to the manual?
#7643
#7644
Originally posted by TRF415boy
Fair enough. Taken this way, it means that the chassis have 3mm uptravel from rest (ride height) to max ride height (when you lift the chassis until the tyres barely touch the ground).
I appreciate a lot!!!!!!!!!!!
I'll try his setup this weekend.
#7645
Originally posted by David J.
I haven’t actually tried this particular tip I’m suggesting but I would get one of those 1.5mm allen wrenches that come with Tamiya kits (any Tamiya enthusiast has a ton of them). Then JB weld it into the stripped screw pin and let it dry for 24 hours and then slowly unthread it. The most common cause of stripping this screw is tightening too quickly during the initial threading into the arm. Good luck.
#7646
#7647
Anyone know the exact number of Tamiya yellow spring? Near 17lbs/in?
edit:
OM.. TryHard page has the info. 13.33lbs/in. THANK U Tryhard!
edit:
#7648
edit:
edit:
#7649
Originally posted by Windtalkers
tot that would be droop???
#7650
edit:
edit:
Later
Ed
