Tamiya TRF415
#3453
Isn't your droop or shock length different the right wishbone sits lower than the left or is it just my imagination
Chazz
Chazz
#3454
Originally posted by T-man
Hi,
Does anyone know if E4P has a website? Looking for the 415 spool. Or are there other brands etc?
Marc
Hi,
Marc
#3456
Went a little bit TRF crazy :)
Got my order. Gotta love blue...
#3457
Im likein that stuff, i wish that had just turned up at my doorstep
#3459
any chance of finding out why you required it?
Anyway, I got a copy of my latest set I've been running. It's so far worked well in stock, both on running track (Don Valley) and sports hall (chesterfield) surfaces.
I've put it on my updated setup sheet for the 415 lightweight arms. I've removed some options, and added in other (ie lower shock mounts, shock lenght etc). I also added a section for the chassis braces' given surikarin (!?!) ran without them on occasion, and a section for the belt tension
link here
415 indoor setup
few things to note.
1) running C/A block on front
2) red roll bar on rear (may change when other springs arrive)
3) Spool and locked centre pulley.
Hope it helps
Ed
link here
415 indoor setup
few things to note.
Hope it helps
Ed
#3462
Re: Re: Went a little bit TRF crazy :)
Originally posted by Runin Ronin
nolan_racing, Where did you get the BLUE maintenance stand? I've been looking for one of those.
#3464
-Dave
#3465
Dave would you be able to give me a web address of a shop in JP with the blue stands as I am after one too.
