Tamiya TRF415
This site might help the confusion
http://www.thard.co.uk/415/415info.html
Lists the info on all the 415 models
Can anyone give me a ball park droop setting for a 75x45 tight 6 turn carpet track? I was running 3 in FT and 4 in the back.
swaybar set.......
I can't find a sway bar set for my TRF415 anywere. I did find a set for the TRF501X. Does anyone know if these are the same size (or even close) to the 415s? As long as the mounting is spaced close to the same, I'll make them work.
But that site says both the MSXX and MSXX-MRE have 2mm lower decks. If that was the case, wouldn't both have the same part number? Aside from the two missing holes I was complaining about, they are cut identically.
I'm pretty sure the bottom deck is thicker on the MRE. I'll measure mine when I get home...
BTW: The lower deck in the MSXX stick-type chassis set is 2.5mm thick and available separately. This plate has all kinds of extra holes drilled in it.
Okay, I just got home and checked. MSXX-MRE 2007 lower deck is same thickness as the original MRE (2.5mm). Side by side they are an exact match. The upper deck is definitely 2.0mm, and when placed next to lower deck, it's obvious the lower deck is considerably thicker.
I have a friend with an MSXX, but I won't be seeing him till next month. I would love to get an exact measurement of that one as well...
my error ... the upper deck is 2.0mm the lower is still 2.5mm
unsure why there is a different part number for the lower deck for the MSXX and MSXX MRE
im fairly sure the ta05 sway bars fit the 415 too, so that might be an option...
And yes, the TA05 sway-bar kit fits the MSX and later and includes all hardware and 6 different bars. You can buy them in rainbow colors 53842, black 49383, or milky blue 49414...
Thanks...........
Thanks guys. It's hard to figure out what fits & what doesn't.
Hey Obsidian. What you think?
Looks good. Get it on the road!
sure does, good luck with the racing...
Come on SPRING!
theres always indoors, guaranteed racing....
I wish..........
That would be great. But there's no indoor racing around here. Maybe some day.
