Tamiya TRF415
I tested the long arms vs the short arms back to back several times last year.
My car felt a litle bit stiffer/less roll with the short arms, the car would square up faster and was a litle more responsive, but the most important part was the laptimes. I was always a couple of tents faster with the short arms!
I never went back to the long arms as the short arms suited my driving style allot better!
Also, Marc won the Reedy race race with short arms, Victor won the Andermach race the week before with short arms.....
So, as long as you like the way your car feels with the short arms, stick with them
Cheers,
Eirik
Cheers,
Eirik
Cheers,
Eirik
Cheers,
Eirik
Hey
Can anyone point me where i can find Tamiya on road spring difference, thanks
Cheers,
Eirik
Cheers,
Eirik
Anyone tried short front, long rear?
I haven't try this yet, but I think short front long rear would be a good combination for asphalt, as most of time I got too many traction on front, too few on rear. Short on front for response, long on rear for traction seems to be a good idea.
However, I did get a more responsive car, but the balance and feel was not right.....
I only changed the arms, no other changes so it might work good if you work on the setup and arm mounts.
Let us know if you try it mate
I am thinking of getting a MRE for asphalt rubber racing. What tuning options and spare parts should I look into getting?
Been reading about the Tamiya MSXX top deck and the short arms (even though I dont quite understand them). Are they used in the front or rear? Do you only need the Evo5 arms or do you need anything else?
Anyone have any pictures of their car with a brushless setup?
Does anyone offer a battery hold down for NiMH or Lipo batteries? Most pics I have seen use tape but I wanted a holder for quicker changes.
Is there a difference between the MSX rear shock tower and the MRE rear shock tower and what are the advantages if any?
Also does anyone know who makes a thicker top plate, upper deck for the original TRF415?
For asphalt and rubber it is recommended to run the spool up front with the locked center shaft correct? How do you accomplish this on the MSXX since it comes with the one-way in the front and the center one-way? What parts are necessary? Is this a necessary change? I have the opportunity to chose between the MRE and the MSXX. The MRE has minimal extra parts and the MSXX has a few more tuning options and spares. They are both about the same price. Not sure which one is the better deal.
What size hex and nut drivers are necessary for the 415 MSX/MRE/MSXX?
Chirag
Chirag
