SMC 40C+ C-Max 7.4V Hardcase Lipos
#271
#272
If you are looking for the new C-MAX 40C Lipos we have them in stock! Check the links below for the capacity!
SMC C-MAX 5200 40C Lipo
SMC C-MAX 3200 40C Lipo
#273
I just placed my order for the SMC 5200 40C Lipo 30 minutes ago. Thanks for the update SuperiorHobbies and Danny@SMC for a kickazz lipo!
#274
Jumping on the bandwagon, I just placed an order. Can't wait to try it.
#275
Orders have been processed and shipping out today! Thanks Guys!
#276
I have over 30 runs on my first 5200-40c and can't tell the difference between that one and my brand new 5200-40c. If it wasn't for the scratch on the older pack I wouldn't be able to tell them apart. They both feel solid through the full 6 minute runs. (13.5 TC)
#278
who else carries these? can't find them anywhere.
Also, what kind of balancer is recommended for these?
#279
Guest
Can anyone explain to me the reason behind the "C" rating on a lipo battery? I assume that the higher the rating (28c to 40c)the more punch? Can you actually feel the difference between the two? Thanks
#282
Typically higher C rate packs should mean that the cells will not drop as much under higher loads due to lower IR. You should only compare C rates to the same brand of packs as there is no official standard for C rate that maufacturers have to use. One companies 25C might be as good as another companies 35C. The materials used and the way the chemicals were blended will also have an effect on the performance.
#283
Guest
Thanks for the schooling on the batteries.
#284
#285
Does mAh has an effect on punchyness of the battery?
Say, is Thunderpower 3200 mAh/40C punchier than Trinity 5200 mAh/35C?
I own both and on a Novak GTB/Novak 17.5, I don't feel there is a difference between the two except the weight.
