Awesomatix EP Touring Car (A700 Shaft Drive)
#9275
Why put rubber sealed steel bearings on a $1000 Rc car ??? I only use Acer ceramic bearings.... Yes , there is a big difference...
#9277
The next step for the A700 in stock classes is drivetrain weight reduction from the all steel 83+gram drivetrain to a potential 32 gram aluminum 7075 drivetrain... I know it will not be as durable as steel, but 50+grams rotational mass loss is very big in stock racing, when you consider that most of the competition's drivetrain weighs around 78 to 90grams...
Just a thought guys....
#9278
#9279
Lightened aluminum parts are the way forward for the A700, and need to be manufactured either by Awesomatix or an aftermarket company... So far, no company has taken up the challenge. If you've heard different, don't hesitate to post the links....
#9282
A manufacturer has to take up the challenge, and build the lightened aluminum parts in order to increase the performance of the A700. I never suggested that people should buy parts that have not been manufactured yet, I just suggested a way forward for the A700. Please read carefully, and understand first, before posting a reply....
#9283
R/C Tech Elite Member
My A700 and Evo 2 both come in at around 1300 grams RTR so I am already having to add 50 grams of ballast, lightening drivetrain parts would be counter-productive for me.
I would like to see a stronger version of P11, seems that they wear out and eventually slip over the pin which causes slop in that diff pinion area, and can bind up the whole assembly. Seen it on a couple of cars myself. Maybe an alloy tube? Most cars which have bearing spacers in the hubs use an alloy one.
#9284
THIS ^^^
Put him on ignore - his entire argument is about lightness. Even though he didn't explicitly say to buy the parts, he's all about modifying parts to make them lighter and then saying he'll be faster even though he doesn't put his car on the tarmac to show it.
