Awesomatix EP Touring Car (A700 Shaft Drive)
#9302
Can you fit a smaller spur gear so you can use a smaller pinion? Looking at the manual a 50t spur and 37 pinion should fit and give you a fdr of 2.81
#9303
Personally I'd just bend the spring rather that buying the new ones. I bent a spring in a big accident and just straightened it and it's been fine since
#9304
Should I be using the 98deg springs with spr02h on d2.1 dampers? I currently using the standard spring and not noticed any issues.
Hi. You will not need bent springs on D2.1 dampers. They are useful on the D2.2 version to prevent play in the suspension.
I've bent springs by hand and this is also a fine method (i.e. I use 110 degree bent springs on the rear). Ride height and droop settings do change with the amount the spring is bent.
Sam
#9305
"http://www.thercracer.com/2013/12/getting-to-know-awesomatix-a700l.html"
Does anyone here have an extra blades or feeler blades for the spring stiffness they would like to sell. I recently purchased an A700L on the for sale thread, but it didnt come with it. Im not sure if that is available for a separate purchase as I dont see one online.
Gen
Gen
#9306
http://shop.awesomatixusa.com/index....scription=true
Damper gauges are available for sale seperatly
#9308
Hope I'm on the right thread. I'm looking into getting an A700 Evoii and trying to find out if there are aluminum arms available for the kit? I have searched and can't seem to find this part for the kit? The track I run on is CRC high bite carpet and all the guys running A800's use the aluminum arms. I know one guy has a A700 that has alloy arms.
#9309
R/C Tech Elite Member
C04al
C04al+0.5 (1/2mm longer)
