Awesomatix EP Touring Car (A700 Shaft Drive)
#9256
Great to hear the shaft cars are at the sharp end, and that development on this platform will continue.
I've been finding my a700 evo2 to be very competitive at the moment, winning both of my last club meetings. I found my a800 ran well there, but on the unprepared low grip track, my evo2 is quicker at the moment. I have some work to do with the a800, with the nationals approaching.
#9257
Agreed. My Evo 2 was very fast at Reedy and a pleasure to drive. I don't plan on setting it aside any time soon. Big thanks to Tony Tam for all the setup help, I kept breaking personal bests with each adjustment, and congrats to Tony on a solid mod A main finish with the belted brother.
#9258
It is a testament to your design that he was able to achieve with what I understand to be a older generation of car. If you or anyone on this forum can tell us what information you need, I will be happy to try and see what was used on the car and provide the team with set up information.
I thank all those running the awesomatix car a heart felt thank you for your support and kind words on encouragement and look forward to meeting more of you at future events. Thanks and will see you at the top.
#9259
It was truly an amazing performance to witness. Lopez really showed the capabilities of this platform even without the latest bells and whistles. No setup sheet yet, but you can see pictures and videos here. Imagine what he could do with just some upgraded dampers
Congrats to Christian for another impressive win at Reedy.
#9260
Thank you Dan. Please let us know what you need in the way of information and will try and post this. Since this is our first time running the car we may not be familiar with want your looking for . Will do our best to post and share whatever is necessary to help.
#9261
Vta
Anyone have a good vta setup
#9262
#9263
I have an Evo2 and an Evo. The roll bars on each car are a little different. What roll bars do I want to order for the Evo? The Evo2 roll bars won't fit, unless I use pliers to bend them as they have an extra bend in them
#9264
PS - I like to use technical terms AKA: "little sausage holders" vs P05
#9266
I will try to take a pic. But the Evo chassis is wider than the Evo2 and the wires that came with the evo2 are too narrow to fit into the blocks. The Evo2 wires measures 87mm along the wire. The Evo wire measures 89mm. The Evo2 wire won't fit the wider blocks. The evo2 blocks are 75mm from set screw to set screw. The Evo is 85mm and that's center to center so a 87mm wire just doesn't cut it unless I sand down the blocks.
#9267
R/C Tech Elite Member
If you need old style bars... We can find some for you. It might just take a few days....
#9268
A700 evo F/S
I posted in the For Sale thread myA700evo if anyone is interested...
Awesomatix A700evo
Our track closed down in February of 2015 and this awesome machine has been collecting dust since then. I built this car for the 2014 IIC race in Las Vegas but didn't run it there. The car is in pristine condition! (minus the dust) Everything in the pics is included... even the very hard to find aluminum chassis. This car needs a track to conquer!
3 spare diffs ($95.00 ea)
Aluminum chassis ($150.00)
Spool ($68.00)
those items alone are worth close to $500.00
Everything in the pics......
$650.00
https://picasaweb.google.com/1168256...74674644449073
Awesomatix A700evo
Spool ($68.00)
$650.00
#9269
Ok so I have just rebuilt my a700 - put carbon arms back on (removed them to put on my a800, but the alu ones don't seem to work as well on the a700) also put the new thinker drive shaft on and removed the bearing brace etc. Ive also removed the carbon top plate and installed a chassis stiffener.
My first question is, how many screws do i need for the stiffener? I currently have one at each end holding it in place - is this enough or do i need a center one as well?
Second Question - will a set of ceramic bearings make any difference to the 700? The standard awesomatix ones seem to be pretty good - anyone used ceramic with any benefits?
Cheers,
Cheers,
#9270
Cheers,
Cheers,
