Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 11-27-2013, 07:08 AM
  #4846
Autocratic's Avatar
Trader Rating: 26 (100%+)
What all will the Evo kit include over the current kit options?
Autocratic is offline
Old 11-27-2013, 07:47 AM
  #4847
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
http://www.awesomatixusa.com/p/a700-evo.html
hanulec is offline
Old 11-27-2013, 07:56 AM
  #4848
hanulec's Avatar
Originally Posted by Adam B
Will this FFG kit be of any benefit in stock? I will probably buy another car for mod soon, but I can see how this could help in mod a lot.
The faster you go -- the better.
The FFG at the Halloween Classic allowed my car to be under better control at the 2nd corner (first left). It was more stable in the tight fast left. I wish I had this part outdoors running mod on asphalt.
At the end of the day -- you need to tune your car. There are still so many settings we havent tried.
hanulec is offline
Old 11-27-2013, 07:57 AM
  #4849
Travis S's Avatar
Trader Rating: 46 (100%+)
Originally Posted by hanulec
I just noticed the center brace that is attached to the new carbon tube. Wondering if not using this would make the car flex to much for indoor carpet? I ask because in both USGT and USVTA indoors is what I run the most and I need to add a lot of weight to the car. I am currently running carbon shafts that allow me to take out that 2 bearing brace for the shaft in the current version, so I can easily add all the weight I need right down the middle. I like the idea of the floating front, but just wondering if the people using it now have tried running the car without that center brace.
Travis S is offline
Old 11-27-2013, 08:51 AM
  #4850
Travis S's Avatar
OMG 17.5 on these carpet tracks seems fast enough! I am still trying to get used to that speed. I guess the floating box might not do much for me then in the slower classes anyways.
Travis S is offline
Old 11-27-2013, 10:45 AM
  #4851
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
It be perfect for asphault racing ..
OVA is offline
Old 11-27-2013, 01:38 PM
  #4852
haywood's Avatar
Trader Rating: 49 (100%+)
Default A700
https://www.facebook.com/photo.php?f...9061444&type=1
haywood is offline
Old 11-27-2013, 04:40 PM
  #4853
hanulec's Avatar
That brace from the chassis helps keep the FFG from moving too much --- and allows the front to rear flex to be adjusted when not running a top deck.
The drive shaft bearing holder extends down from the FFG shaft.
look at the facebook page to see more pics..
hanulec is offline
Old 11-28-2013, 01:15 PM
  #4854
ropezz's Avatar
Instead of FFG i wonder how an elastic joint on center shaft woul have performed !?
ropezz is offline
Old 11-28-2013, 02:26 PM
  #4855
Probably too much resistance with an elastomeric joint. You will be surprised how easily the floating bulkhead moves. Barely twisting the chassis causes the bulkhead to move.
malkiy is offline
Old 11-29-2013, 02:43 AM
  #4856
We have an analog of such elastic joint already - SD1 spur damper.
But any elastic joint doesn't remove the transfer of the torque from transmission to the chassis.
It only dampens the torque oscillations but doesn't affect on the average torque transfer.
FFG removes the transfer of the torque to the chassis completely (actually zero transfer).
Oleg Babich is offline
Old 11-29-2013, 08:27 AM
  #4857
erchn's Avatar
I'm actually curios as to why FFG doesn't transfer any torque to the back of the chassis through the tube? Note: it's highly likely I'm not seeing the whole picture, while looking at the pictures. :-)
erchn is offline
Old 11-29-2013, 09:24 AM
  #4858
I guess the tube rotates at the center brace and at the rear connection point, or it can just spin at the front connection....
bertrandsv87 is offline
Old 11-29-2013, 09:26 AM
  #4859
hana166's Avatar
Yea its a tricky one to think about, I dunno, maybe because the gearboxes are rigidly connected to each other via carbon tube allows torque cancellation via the tube rather than using the chassis? Its pretty clever!
hana166 is offline
Old 11-29-2013, 09:31 AM
  #4860
Smile
It is an evolution of the top deck design for sure... Does it come as an upgrade kit ??? If so, how much will it cost ???
