Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 09-06-2013, 10:50 PM
  #4246
Travis S's Avatar
Trader Rating: 46 (100%+)
Originally Posted by oldrcr
your lucky to have gotten it at all.
I have a feeling that triangle has some relevance near Bermuda.
Yeah I was freaking out for sure when I saw it route to Puerto Rico from Louisiana. Then it when to Chicago area that is about 2 1/2 hours East so I thought I was in the clear. Then it went BACK to Louisiana! Then flew to Des Moines, IA 2 1/2 hours West of me. I finally got it today.
Travis S is offline
Old 09-07-2013, 08:55 AM
  #4247
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Travis - Gee's setup should be good for ya. I have a slight variation of Gee setup by Matt Abey that I'll post soon. He tried to tame the car down/make it less aggressive.
Our friends in Colorado should also have some interesting setup ideas after a three day practice set over at 5280 this weekend.
hanulec is offline
Old 09-07-2013, 10:06 AM
  #4248
Anyone run sweep premounts lately? Are awesomatix drivers still having to modify their hex adapters in order to run these rims?
malkiy is offline
Old 09-07-2013, 01:10 PM
  #4249
hanulec's Avatar
Sweep rims appear to be back to normal... Without usage issues
hanulec is offline
Old 09-07-2013, 02:30 PM
  #4250
Trader Rating: 17 (100%+)
Originally Posted by Travis S
Anyone have a high traction carpet setup for the EXL? I saw Mike Gee's for the L here but wasn't sure if there was a setup for the EXL. I will be running USGT (21.5) on treaded tires at the Southern Nationals in a couple weeks. I guess it will be sink or swim for me. I won't have any track time with this car until then... So I am hoping for a good starting point to work with.
Glad you got that figured out....mine went fine for the 1st try, but my kit only has 1 pin for the shaft so I have to retrofit a short pin for the rear of the shaft.
Once you have the carpet setup, let me know so I can use it at Hurricane series...I am also going to run it for 21.5 USGT carpet after using it for mod ourdoor at LHR. I have quite alot of ppl to dare me to run it for USVTA....I said, why not....
Solara is offline
Old 09-07-2013, 03:53 PM
  #4251
Travis S's Avatar
I am having a some trouble deciphering these setup sheets... I am trying to use Gee's setup but I don't know what holes I should be using on the upper links for the front and the back.
I have found these pictures that show what my car looks like, but according to the picture the holes available do not match up with what the setup is using.
In the front the setup is using the 2nd hole from the right on both but the picture shows I only have the 3rd,4th,5th hole options in the front and 3 and 4 from the right on the back.)
The back shows the 2nd hole from the left in both spots but I only have the 3rd hole option. Do I need an optional part to run this setup or what am I missing.
Travis S is offline
Old 09-07-2013, 04:19 PM
  #4252
hanulec's Avatar
Travis- Gees setup uses the inner holes on the am19.
Inner holes on am19 equals outer holes on am18.
Mike
hanulec is offline
Old 09-07-2013, 04:21 PM
  #4253
Travis S's Avatar
Mike
I hope you haven't shipped my order I put in yesterday... I guess I will need to add them to that order if I can.
Travis S is offline
Old 09-07-2013, 05:11 PM
  #4254
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Upper links inner balls location on A700 and A700L&EX.
Please note that the third hole from the outside is the same for A700 and A700L/EX and this hole is the outer hole on AM01/AM01-1.
go to the 2697 post number for the picture page 180
OVA is offline
Old 09-07-2013, 05:33 PM
  #4255
OVA
OVA's Avatar
OVA is offline
Old 09-08-2013, 07:47 AM
  #4256
Hi guys
Looking at getting the A700L soon as well..i really want one, im going from an MI5 to this.
Anything i need to take into consideration?
also who is the stockist for United Kingdom buyers?
PurcyP is offline
Old 09-08-2013, 12:23 PM
  #4257
Originally Posted by PurcyP
Hi guys
There isn't anyone who brings them into uk best to get them direct from Oleg
T garnham is offline
Old 09-08-2013, 02:10 PM
  #4258
Hi guys
Hi , what club do you run at in the uk ?
I will be at mendip btcc next sat/sun if you want to know a thing about the car
r king is offline
Old 09-08-2013, 03:18 PM
  #4259
Trader Rating: 27 (100%+)
One TQ, 3rd in 17.5 & 2nd in Mod. Not a bad raceday. Thanks Awesomatix, ORCA and Team Larcher!
MDawson is offline
Old 09-08-2013, 07:04 PM
  #4260
holy crap mark...wheres the artwork paint??
FUBFTC is offline
