Awesomatix EP Touring Car (A700 Shaft Drive)
#3241
i see this after ordering some other stuff .
tower has some amazingly small Robinson gears-- the 55 and 60 look to be some good options..
Robinson Racing Spur Gear Machined 48P 49T
Robinson Racing Spur Gear Machined 48P 52T
Robinson Racing Spur Gear Machined 48P 55T
Robinson Racing Spur Gear 60T Stealth Pro
Robinson Racing Spur Gear 66T Stealth Pro
#3243
#3244
I was geared 4.06 at nats, and had the fastest car in a straight line as far as I could tell... 80 spur fits up to a 3.33 according to the book
#3245
I again, as for my problems with the car, its all over.
It was a error 40, the rear right toe link was loose.
Now it works nicely again.
#3246
hello there, i need some help, iīm having a tweak issue, i canīt do it well, is there any way to do it properely.
thanks
Mr Bear....
thanks
Mr Bear....
#3247
I would try to unscrew all your topdeck screws including the pivot balls.
After that, press the chassis on a flat board an screw the topdeck.
I'm not sure if that was your question but i think
#3249
MMMMmmmm......I'm about 60% done with the build on my new A700EXL and all I can say is wow!!!! This thing is so nice I now see why it has the price tag is does....well worth the money spent I do have an issue/question, when I build up the gear diff it seems notchy and tight like I'm running thick lube but I'm only running 1000wgt. Are there any tricks you guys are using to get the diff smooth? Is there something I need to look out for when building the diff? Thanks in advance...
#3250
#3251
#3252
I would do the gear diff modification. By doing this, the gears become smoother and won't wear out too fast
I can't post links yet for any reasons, but you can find it on petitrc or on the awesomatix web site
Hope this helps
Hope this helps
#3254
Hi all,
I'd like to know where to use ST24? Above and below AM06(S) or just above?
Regards,
G-rem
Regards,
G-rem
