Awesomatix EP Touring Car (A700 Shaft Drive)
#3991
R/C Tech Elite Member
Hi
I wondering about the upper arm links should i use the long or the short of the links, i have seen pictures where the long is in the front and the short is in the rear . So what is the different and what is the best to use and what length should the arms be ? .
Best regards
Frederik
Best regards
Frederik
http://awesomatix.com/download/
http://www.petitrc.com/reglages/awes...matixA700.html
http://www.awesomatixusa.com/p/setup-sheets.html
http://racerlog.com/wiki/Awesomatix_A700
#3992
Top 4 finish at the Euros! Wow! Congrats Freddy--
Rank Licence Add. Driver Nat Club 1. Heat 2. Heat 3. Heat Heat Points per Run Points
1 D985 009--Ronald Völker DE 22 5:13.693 (1) 21 5:01.561 (1) - (-) A 1:1, 2:1 [3:10] 2
2 S174 056--Alexander Hagberg SE 22 5:14.096 (2) 21 5:01.656 (2) 21 5:04.314 (1) A 3:1, 1:2 [2:2] 3
3 GB 480 027--Elliott Harper GB 21 5:02.010 (3) 21 5:02.817 (3) 21 5:07.956 (2) A 3:2, 1:3 [2:3] 5
4 D1086 011--Frederik Südhoff DE 1 0:04.952 (10) 21 5:06.589 (4) 21 5:08.881 (3) A 3:3, 2:4 [1:10] 7
5 NL-503 060--Jilles Groskamp NL 21 5:03.411 (4) 21 5:07.952 (6) 21 5:10.913 (6) A 1:4, 2:6 [3:6] 10
#3995
Frederik- this is all part of the hobby --- finding out what works w/ your track condition and tires. i'd recommend you select an existing setup to begin with either because of motor class or tires used w/in the setups. you can find setups at--
Best regards
Frederik
#3996
The camber link size varies on the mounting point. The kits links work well for all of the "on bulkhead"/am01 mountings. shorter links are required if your using the optional plates -am18 or am19. Pettit has a page talking about how to read the setup sheets by knowing ehich hole is which for the upper links.
#3997
New kits
I'm really pleased with my a700exl but would really like to expand the fleet.
#3998
Okay thanks for your help
Best regards
Frederik Broløs Mikkelsen
#3999
Congratulations to Freddy and Viljami for the succes at EC 2013!
Our trial "floating front gearbox" set was good.
After some refinements we will definitely use it in our new kits that we are preparing for 2014 season.
The other good thing is that this set works well on our standard L chassis.
Viljami has used L-chassis right from the EC practice beginning and Freddy has switched to L-chassis also for A-mains after his trial 2.1mm chassis was broken.
After this Freddy's switch the car has becomes even better.
Unfortunatelly we didn't have enough time for the testing of all possible configurations available with "floating front gearbox" set.
But this initial result is very promising.
I am happy that Awesomatix drivers will have the possibility to get even the more faster and innovative cars soon.
#4000
Dear Oleg,
Greetings from Portugal! It was a real pleasure to have met you and share some words about the creation of your masterpiece. We were all overwhelmed by the beauty of the awesomatix and the new free floating front gearbox! A true work of a genious. We are very fortunate to have you as a creator of r/c model cars and I thank you for that.
Regards,
Fernando Cordeiro
Regards,
Fernando Cordeiro
#4001
Dear Oleg,
Regards,
Fernando Cordeiro
Regards,
Fernando Cordeiro
Thank you for so kind words!
I am very impressed by Portugal in many aspects and I hope to visit your beautiful country in future again.
#4003
Hi Oleg
Which lower deck will there be on the new Awesomatix a700 if it will be a 2-2,5 mm will there so be somthing to support the bumper like Xray had do so the front of the lower deck not will break ?
And congratulations to Freddy and viljami for there great results in the Euro championship
#4004
Oleg,
could we have some pics or drawings of the new parts? Can't wait to see the 2014 version of the car
Do you plan to make a conversion kit for all current owners of A700L/EXL?
Best regards
G-rem
Best regards
G-rem
#4005
Hi Oleg
Do you have any problems with the chassis bumper area strength now? Please let me know.
Our first A700 chassis have had the additional holes under the front gearbox but we have removed them later for increasing of the strength.
L and EX chassis have 2.5mm thikness under bumper already.
We don't have now any reports from the customers concerning the breaking of the chassis near the damper.
BD7 and 417 cars also don't have the additional supports for bumper.
Do you think that we have to add such supports for new car?
