Warpspeed Demon and Demon 2
#2371
WARPSPEED RACING
John,
You've got PM.
You've got PM.
#2373
yea tony we raced !
ran two qualifiers and during the break it rained for ten minutes and dried up quickly.
I TQ stock! and was leading Until I developed a mid race glitch for two laps I got Passed by a local kid who is a good driver. then the glitched disapeared I caught him was trying to pass him on the inside his car stalled mid corner I was on his tail punted him, and like a true sportsman I waited but he hit me stuck my body under and took off! You believe that so much for sportsmanship! Other then that the car ran great! sorry you guys didnt race!
#2374
We haven't had too many rain-outs all summer, so we just hung out and rested today. We may try our luck at oval tomorrow at Quaker Steak. Toni has a pick-up truck all painted and ready to go. They run nascar style trucks ,we will see if the weather holds up. It may not be our favorite racing venue but it is still racing. See you next month in Orlando.
#2375
good luck guys !
#2378
Actually I took a dremal and just made a curve in the top deck big enough to twist and lift the motor out. even though you shouldnt have to there is no reason to unscrew the top deck.
here is a pic dont think you can notice but I ground it down with the natural lines of the top deck you cant even tell.
#2379
Originally posted by speedxl
dotman I use the steel ones also because when running a spool it acts as a heavy flywheel and keeps the car rolling yes it doesnt accell as quick but you dont really notice too much. I rather have smoother decell. also I run mod and 19t turn alot so due to horsepower I dont notice a difference. Run the metal outdrives trust me you will like them.
#2380
yea kinda sorta but the composite ones brake and you cant tieghten down to much and when the track is 145+ degrees running a mod motor the composite one dont hold up. such is the case with 19t.
especially on tight technical tracks were you accell and decell alot while the diff is working on overload.
#2382
once I started using the steeloutdrives I never switched back. also you can get the alloy ones they wear out quicker but they are lighter!
#2384
dotman you can use schumacher blades. just have to locate someones bent axle and tap out the pin and use the blade they fit snug and handle more abuse, especially compard to the IRS pin cushins!
#2385
For the people who have driven the d1 and d2 which do you like better
