XRAY T2’009
#436
Gary, that's a good point. I put away my warmers for the last heat and main at last fridays club race and the car seemed better. It's hard to tell for sure, I'm making so many set up changes between heats. I have no doubt that front tire temp is a factor in all this though. Have you temped your tires after a run?
#437
Adam the 009 fully loaded at spec weight without body is coming in at 50.35% rear and 49.65% front, left to right is within 2 grams of each side.
#438
#439
The stock bearings for the aluminum steering knuckles are 5x9x3, without the composite inserts you need 5x11x4. Avid RC carries them.
#440
My tires are coming in at LF 89.8 RF 89.7 LR 88.9 RR 89.0, but I'm still not really happy with my setup. The test track we ran on Saturday had a fast sweeper to a long straight with a hairpin at the end. I figure if I can get the car to feel good at the end of that she should be good to go for most of the venues we are running. Testing continues.
#441
Mostly lose on entry, inconsistent. My setup is very close to yours except I'm running 1mm front droop and front roll center high, 1.6 bar in front and 1.2in rear. Speed 6(wing pushed back), jaco blues / jack, LRP - punch 8 / trinity 13.5 same brake settings as you. Pretty obvious that you like a little more steering from your setup.
Don't get me wrong the car is very quick, it's just a handful to drive, feels like it's on the edge. The 008 on the other hand feels very planted.
When I pulled the rear bar off last night for the main it was better. The real kick in the butt was, the car wanted to traction roll in the sweeper with no rear bar, when the tires warmed up but, it was still a little lose in the infield!
I did try the LTC body last night which may have been a factor (usually run speed 6) but they're pretty similar in terms of feel.
#443
#444
http://www.pmhobbycraft.ca/store/ I know they have some lightweight LTCs in stock right now. Don't know if it matters but IMO the speed 6 is still better overall than the LTC. Lots of locals have tried it and always go back to the Mazda. It's just a little twichy for most guys it seems but, not near as aggressive as the R9R.
#445
what servo arm can i use for a hitec servo?
thanks
josh
thanks
josh
#447
Quick question, is the T2 '009 and T2 '008 chassis the same regarding all the cut-outs?
#449
And you can have T2'009 EU chassis on T2'008 EU car without any mod. I've it on my T2'008.5...
#450
UPDATE!
Team Xray T2 009 screw kits are now in stock!
Team Xray T2 009 197-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts and set screws. Please note the 3x4mm Button Head Screws for the spur gear (Xray Part # 902304, pg 12 in the manual) are not included in the kit. Please obtain these from your nearest Xray parts supplier.
Thanks and best regards,
