XRAY T2’009
#1696
There are other sheets for the same track if you look on there.
This is for wlrc.co.uk, the track has fairly low grip compared with a lot of asphalt tracks as the tarmac is nearly 20 years old.
#1697
That stuff does work, but I needed to raise my chassis 1.5mm to make legal height again. Car then started lifting inside rear tire around corners, so took it off and lowered the car again and was fine, thats why I went back to contact and just replaced it more often, but which ever works for you.
#1699
General consensus is that the stock plastic ones are fine. I'd think if the Aluminum ones were better for any reason you'd see them on the Pro Team drivers guys, which you don't.
#1701
What do you think about mi4 mate? I Think you've got both 009 and mi4 ...
If you compare them which one do you think works better on Track?
Thanx in advance
Thanx in advance
#1702
They are both very good cars. With good setup it's about the same in terms of handling.
I personally like MI4 more, however it has it's downsides (nothing's perfect ) - not covered diff like Xray have and blades on front driveshafts.
I'll tell you experience of other local guy - he raced Xray before and switched to MI4 recently and he says it's much easier to drive for him - he just love the car.
#1707
hey guys does anyone know anything about the so called T3'000 comming out? or is it just rumours lol i wud really like to know
cheers
cheers
#1708
is your 009 running yet? did you end up getting the tekin or are tou still running the LRP?
#1709
Lol. ant that the truth.. i think ill have to put a few more layers on .
im still w8ing on the tekin its ment to be due in late this week, i sold the lrp so i havnt been able to get down there.
to give it a run
started a new job tho so ill have the weekend free again.
#1710
lipo balancing chassis weights
Has anyone tried them? I've heard some packs won't fit. I have a smc 3200 40c hard case as well as the ip 3800 35c hard case, does anyone know if both these packs will fit?
