Talkin' with Josh Cyrul
#2117
Originally posted by Josh Cyrul
.... Not sure what you mean about the ball cup....
I was wondering though, are you running a Novak diode and can I install one if running stock or 19T. The reason I ask is that I'd like to start using mod during practice days without having to remove the diode.
Thanks! Tommy
#2118
josh, i could se some more stearing out of my c12, right now i am running this for a set up...
shock, 25 wt, green spring
reg. losi hydro fluid in the dampners
center hole in the front plate, with 1 turn of pre load
i have been runninf 3.5 ride height front and rear(measured at the motor)
i am also using an asc t-bar...
for tires, i have used pink, dbl pink, and grey, purple
i am racing stock, so any hlp would be great..
thanks
matt
thanks
matt
#2119
Josh,
How would you rate your new 12th scale body (in relation to your original)? More steering, less steering etc. Would either be better suited for stock or mod?
#2120
Nick - I am no longer with Xray and I will be working with/racing for Kyosho on a new TC.... No release date planned.....
kid - That's just a regular ball stud that Xray makes. It's not one of the balls that you need to use a screw through..... The diode is a KO dual one that they sell optional for the KO speedo....
Mr. Losi - You could use more steering or you could use steering out of your C12... Sorry, I'm just a bit confused.... Please clarify....
jrrc - I think it has good steering, smooth feel but still very quick to change directions due to the low CG but the biggest difference is the rear bite - it's definatly planted!!
#2121
Josh, On my t1fk I put spacers under the rear camber links and it made the rear rotate much better around the corner. It actuallly lowered the rollcenter which would seem to actually make the back stick more. I was reading over some of your previous threads. You stated earlier that it is because of more camber change. Is that the reason? What is the effect of spacers under the front?
#2122
Hey josh! I'm from Manila, Philippines and currently my team is running team magic's G4 evo. Just wanted to say that we were able to get a copy of an old rc mag that had your former G4 featured in it. it helped us get our cars dialled in right.
just wanted to say good luck and best wishes!
#2123
Josh - Thanks for sharing your carpet nats setup for the XRay. I ran it tonite and it was money.
#2124
#2125
Jim - Putting shims under the outer rear ball stud gives you more camber change and raises the rear roll center. The car does have more steering this way.....
jayps - Great!!!
Shiloh - Excellent!!
kid - No, but it gives me the room to raise it a lot higher if I want to. I did use that same ball stud in the front but again, it's set-up to be in the same height....
jayps - Great!!!
#2126
Josh
im running the RRR and i wanted to know what does changing the front upper A arm hieght do and how does it affect your steering?
#2127
i would like the car to roll through the corner more....sorry for the confusion...more corner speed
#2128
Ian - It is on production and we have been selling the body for a few weeks now. Just go to www.cefx.net and drop me an e-mail for the info...
#2129
Josh - you running TC at the birds? if so, what will you be running since you're no longer with xray?
#2130
chassis
Josh - I’m sure you have tried all of the Xray chassis (plastic tub, oem fk, and 3.5 rigid). Is there a place for each? Is there an application where one chassis would work better than the other?
