Tamiya TB-02
Old 09-15-2005, 09:01 PM
  #1486
f1larry's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Hebiki
for those new to the TB-02/EvoIII... there are several REVISIONS for the shaft.
original EvoIII shaft
evoIII lightweight shaft - 2mm longer (skinny bevel ends)
TB-02R shaft - same length as evoIII lightweight shaft but fatter bevel ends (the part that goes into the bevel gear). this is the NON-lightweight version.
and finally... the BLUE lightweight shaft is 2mm longer than the evoIII lightweight shaft AND has the fatter bevel ends. this shaft is 4mm longer than the original evoIII shaft.
if possible, pick up the blue version. ill post the part # when i get home later.
I don't think the Blue shaft is available by itself. I think i came with the EVO III blue conversion kit #49335, If it is available by itself though I would love to get it.
f1larry is offline
Old 09-15-2005, 10:29 PM
  #1487
rchoudini's Avatar
49369 RC TBEvo3 Ltwt A Prop Shaft (Blue)
It is available.
rchoudini is offline
Old 09-16-2005, 12:25 AM
  #1488
Hebiki's Avatar
Trader Rating: 26 (100%+)
It is available.
right part #..but the header card that i have says TB-02R Lightweight aluminum Propeller Shaft (Blue)
thats old school. the one in the conversion kit is still too short and has the smaller tapered end. you want the one above
Hebiki is offline
Old 09-16-2005, 06:35 AM
  #1489
f1larry's Avatar
It is available.
who has one available, I looked on R10 and did not see one. I will send them an email to ask, if you know who has one in stock let me know.
f1larry is offline
Old 09-16-2005, 08:37 AM
  #1490
tony q's Avatar
Trader Rating: 35 (100%+)
try jasons store at E-BAY. i bought one last night. just type in tamiya tb02 and scroll down.
tony q is online now
Old 09-16-2005, 09:04 AM
  #1491
f1larry's Avatar
Tony,
Thanks, Just bought a couple now.
f1larry is offline
Old 09-16-2005, 10:45 AM
  #1492
Hawk6's Avatar
Trader Rating: 52 (100%+)
I have a couple questions on the TB-02:
Are the kit tires (slicks), Tamiya "Type A", "Type B", junky kit tires, or something else?
Is adding rear toe-in recommended. My Associated TC-3 has I think 3 degrees rear toe-in, as far as I can tell the TB-02 has 0.
My specific model is the Nissan Xanavi. The TB-02, not the TB-02R.
Thanks.
Hawk6 is offline
Old 09-16-2005, 12:44 PM
  #1493
Charles_Howarth's Avatar
The kit tires are just that, kit tires not A's or B's.
Charley
Charles_Howarth is offline
Old 09-16-2005, 03:15 PM
  #1494
Hawk6's Avatar
So, are "just kit tires" somewhat useless, not worth saving for a TCS race, etc. Are they decent?
What about the rear toe in, any opinions?
Thanks.
Hawk6 is offline
Old 09-16-2005, 05:11 PM
  #1495
tony q's Avatar
Thanks.
you don't have to throw away the kit tires just save them, put nice rims and save it for the TCS concourse. and about the rear toe-in you can change the toe-in by putting different blocks B,C, or D. you will see the difference when you try it.
Old 09-16-2005, 06:09 PM
  #1496
Hawk6's Avatar
Thanks. What rear toe in blocks are recommended for the typical carpet road course?
Is a B = 1 degree, C = 2 degree, etc. or something else??
Hawk6 is offline
Old 09-16-2005, 07:11 PM
  #1497
tony q's Avatar
i'll probably go w/ less toe-in, due to (carpet) has a lot of traction.
Old 09-16-2005, 07:16 PM
  #1498
Hawk6's Avatar
Thanks, but I'm gonna keep asking questions.
What's "less" toe-in? 0 or 1 degrees?
Am I correct that in stock form the TB-02 has 0 degrees toe-in in the rear?
Hawk6 is offline
Old 09-16-2005, 07:53 PM
  #1499
If you have the old suspension, then your rear toe out of the box will be 2 degrees. The way tamiya blocks work are very simple. A block is 0 degrees,
b block is .5 degrees and so on. So, if you've got two A blocks in the rear with the old suspension, your total toe will be 2 degrees. Change the rear block to a B block and you will have 2.5 degrees and so on.
Juan Aveytia is offline
Old 09-17-2005, 12:15 AM
  #1500
dsrbltoys's Avatar
hey juan. whats up dude I do need to step in and say the stock uprights on both the new and old suspension is 1 deg. The old suspension has a 2 deg hard version, and both a standard and hard plastic 1 deg. The old and new suspension also have a 1 deg alloy availaible, and the additional 0 deg upright for the new lt/wt suspension. You can add or take away by using different susp pin mount blocks. the plastic are "a"'s and then you have the whole range a - e, each higher letter adds .5 deg per side.
dsrbltoys is offline
