TAMIYA F103 RM
#646
thanks
i would buy the car maybe at christmas.
would it run better if i put a sport tuned or a motor like this in the f103?
i can run the sport tuned with the mamba esc right?
#648
i like foams i do, but is it true that they actually do have rubber f1 tires avail for the 103 line?
R
R
#649
TRG has some rubber tires for the F103.
I know Tamiya used to have some but I don't know if they're still available (53138, 53139)
#650
The TRG rubber tires are excellent IMO. I bought mine from RCmart, but other places have them now. I looked for Tamiya rubber tires, but had no luck. I recently assembled a F312T3 and it came with the Tamiya rubber tires, after mounting them and glueing them up, I like the TRG tires better. The rubber compound seems to be stickier, the foam inserts are not too bad, and I believe them to be belted like a normal touring car tires.
#651
Is anyone having trouble with the front TRG rims? The bearings seem a bit too loose causing the wheel to wobble? I'm using the kit bearings.
#652
I think that on such a car, steering expo is a godd thing (I set it to -25% on my Futaba 3GR) but I didn't have to set a throttle expo or EPA, with a 9.5 Eraser (it was this week end, on a unclean track, on my F103 GT, so with 26mm touring foam tires, instead of the 45mm rear foam tires). The only point is that 25 shore foam tire can last 6 packs, so a bit more than 2 hours, no more...
#654
Hey James, the F102 wings will work with the F103. The rear is a direct bolt on. The front needs a little modifying but it can work. You just need to cut off the two front parts that stick out and keep it from sliding into the A-arm bulk head. Once those are trimed off the wing should slide in with out a problem. If you get it and have questions just shoot me a note, I'd be happy to help.
#655
What do you think Vyger.. close eh?
#657
MS Jordan Decals
http://d-drivesportsenglish.com/inde...products_id=75
#658
I finally got around to taking pictures of my F103RM.
Let me now what you think!
#660
yep.. dont really have much choice if I am going to really do a 191 M. Schumacher.
I think the $25 us price tag is a bit much.. but there will be lots of decals left for another project.
I am still using up decals from my original Road wizard sheet!
James
James
That's a great looking car. I got one of these a about a month ago. TRG did a great job shaping this one. The only problem is there aren't any trim lines for the front A-arms, steering links and wing. So you'll have to get creative when it comes to trimming this one out. I think it should be a great platform for the 191 build you've got in store for it. Make sure you post up some pics as you go. I'd love to see how you work it. Are you using the decal sheed from D-drive?
MS Jordan Decals
MS Jordan Decals
