Tamiya TB-03
#737
Only there 4 days, yeah TCS is my main thing but figured since I was there I would try to hit up some other tracks. Will have to see how T.Marshall feels after friday Plane tickets are cheap to CA from NC maybe I can HEHEH
#739
Heheh yes i did I had to cut another car out of the picture, paste the asphalt from other layers, cut out my car from another picture, blur one layer, copy paste a new layer, smudge tool, used a stamp thingy for the wheels...blah layers are a pain in the butt
PM back.
#740
Oh wow that's beautifully painted! How did you do the masking for the pink stripes? Did you use tape or liquid mask? I used tape on my GT-R, but came to grief at certain spots where the tape came loose Had to do some rescue work with creative placements of the decals...
#743
DROOP
Do you guys change the droop of the car? or you just use the 2mm setting stated in the manual? Thanks!
#747
Im just wondering why the droop settings is not included in the TB03 setup sheet?.
#748
Basic way I tune with droop is this.... More on power steering, less droop in the front. More off power steering, more droop in in the rear. More rear traction on power, more front droop. Less off power steering, less droop in the rear. Hope I explained it well enough
As far as pushrod length, I use 14mm for most of my setups but do shorten or lengthen them from time to time. The length that you use will depend on other areas of your suspension setup. Things that will change this are what length springs you are using * some of the springs I use sometimes have 4mm difference in height to Tamiya springs...* what ride height you are trying to run at, and what droop setting you are using. The big thing in my opinion to look out for with pushrod tuning is to adjust these to keep the suspension from pre loading the front springs and binding your suspension. Get this adjustment wrong along with droop for instance, and you will have the suspension fighting itself just sitting on the bench.
#750
I've been experimenting with different push-rod lengths and with higher profile tires (like RCGT X-patterns) and regular touring car length shock springs, it helps when you shorten the push-rod a bit, so you have more spacing on the pre-load collar to work with on the ride height. I try to keep the push-rod lengths equal left and right, and adjust for droop through the A-arm's droop set screw.
Steve Wang
Steve Wang
