Like Tree5Likes
Tamiya TB-03
Old 03-24-2009, 04:45 PM
  #226
TryHard's Avatar
Originally Posted by VR6T
i found thats a lot of choice of suspension mount for TB03..
just wonder whats the different between those mount?
1A
1B
1C
1D
1E
1F
1XA
1XB
1XC
1XD
which 1 of those is recommended to use for drifting set up..
TQ
Not sure about what's recomended for drifting, but I would guess the kit blocks are in the ball park.
As for what they do, have a look here
THard.co.uk Suspension block guide
It's for the 416, but the TB03 uses exactly the same blocks (as do
most of the other Tamiya kits)
HiH
Ed
TryHard is offline
Old 04-13-2009, 08:28 AM
  #227
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
Anybody here has got torque steer issues with the left turns???
KELVIN KHNG is offline
Old 04-18-2009, 08:40 PM
  #228
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default tb-03 and tb-03d
i ran tb-03 and tb-03d at tamiya track today, and it was fun. track had good grip. tb-03d handle better then tb-03. both car had stock manual set up, aluminum shocks (3 hole/ 40wt oil), front cvd, spool, rp30 tires, co27 motor (7.xx fdr). cars were bit fast for my skill. thinking of putting silvercan motor. also tb-03s handle much better then my tb-02
p.s: thanks for guys helping me out at track.
Phat-Boy is offline
Old 04-21-2009, 07:29 AM
  #229
Swift and Sleek's Avatar
Smile TB03 BUILD UP
GUYS,
I JUST GOT MY TB03 BUT UNFORTUNATELY OUR LHS DOESN'T HAVE THE ALUM DIFF JOINT CUP YET AND THE FRONT ONE WAY. ARE THERE ANY BUILD UP TWEAKS, TECHNIQUES, OR SHIMMINGS THAT IS NEEDED TO BE DONE FOR ME TO GO THROUGH THE BUILD UP ONCE SMOOTHLY.
THANKS A LOT!
Swift and Sleek is offline
Old 04-23-2009, 01:02 AM
  #230
Hebiki's Avatar
Trader Rating: 26 (100%+)
were you the one i was yelling at to "sell it"? while you were running?
Hebiki is offline
Old 04-23-2009, 01:03 AM
  #231
Hebiki's Avatar
does anyone know of a hobby shop that has the carbon reinforced tub in stock?
Hebiki is offline
Old 04-24-2009, 11:24 AM
  #232
Phat-Boy's Avatar
Default carbon tub
even tamiya usa do not have in stock.
Phat-Boy is offline
Old 04-24-2009, 11:50 AM
  #233
AWK
AWK's Avatar
That TB03 deck is not sold in the U.S. yet, and I didn't see any on eBay even!
AWK is offline
Old 04-24-2009, 12:24 PM
  #234
J.Dy's Avatar
That would be me
J.Dy is offline
Old 04-24-2009, 04:05 PM
  #235
Hebiki's Avatar
Originally Posted by J.Dy
That would be me
oh hey!!! whats up!
so are you gonna sell it?
Hebiki is offline
Old 04-25-2009, 10:24 AM
  #236
due out in 5/30
#54147
redbones is offline
Old 04-28-2009, 10:29 AM
  #237
jrxs-r's Avatar
Hey all....
Won the local carpet 540 championship with a 95% stock TB-03IFS. Was in one final a lap up from the nearest driver. Awesome car to drive out of the box, and was the quickest (laptimes and laps in 5 mins). Only hop-ups were front 3Racing universals, and Tamiya Spring Set. Car was built as instruction manual bar the following-->
A rough rundown of my setup:
Sports Tuned 540 Motor - 5.77:1 FDR
Springs - Blue (Front), Red (Rear)
Shock Oil (plastic shocks) - 80WT w/2 hole pistons
Droop over ride height - 3mm (Front), 2mm (Rear)
6mm Tamiya Alloy Hexes on Rear, Standard Plastic Fronts
Yeah Racing 3200 Lipos
Weight - 1520g w/PT
Tamiya Type A tyres with Med-Firm Inserts
Body - Protoform Dodge Stratus 3.0
Hope this helps someone!
jrxs-r is offline
Old 04-30-2009, 10:02 AM
  #238
Smile CARBON VS PLASTIC
HAS ANYONE HERE TRIED TO WEIGH THE CARBON REINFORCED PARTS AGAINST THE PLASTIC PARTS FOR THE TB03? WHICH ONE WEIGHS MORE?
Old 05-01-2009, 02:39 AM
  #239
Hebiki's Avatar
Originally Posted by redbones
due out in 5/30
#54147
sweet. thanks!
Hebiki is offline
Old 05-01-2009, 04:27 PM
  #240
I just got the 3Racing CF chassis yesterday for my TB-03. It's pretty sweet. The chassis comes with a completely redesigned steering assembly. Also it comes with a metal motor mount. I already had the hopped Tamiya steering assembly and aluminium motor mount (both of which are better than the ones that come with cf chassis) but those can't be used with the 3Racing CF chassis. No biggie I'll just throw them on my TB-03D chassis. Everything fits pretty well except for a couple of design bugs. Because the new steering assembly is so tight there is a little interference on the turnbuckles if you try to turn when the front arms up (shocks compressed) or if you set up with too much droop. To fix this I had to screw the ball joint in on the front axle upside down which lowers the turnbuckles giving more clearance. Also because of the new steering assembly the servo is mounted 90deg counter clockwise from the stock chassis. With the hopped servo mounts the servo won't clear the steering linkage (by a few mm). I fixed this by reversing the mounts and pushing the servo more towards the side. but now the servo hangs about 1/2" off the side of the CF chassis. Now its a low profile servo so if you had a full size servo it would really be hanging off. I'm gonna try and find a smaller servo mount or just make my own with a small aluminium block and screw tap. Another thing that kinda sucks is that the Spur gear and pinion are now exposed. No bigge but it was nice on the stock chassis when I didn't have to worry about little pebbles getting in there. Oh one more thing they forgot one thing in the box. The angled ESC mount is missing. No biggie as I could just make one on my RP machine, or go without it, but it still sucks that it was not in there since I paid for it. Considering the problems that arised and the fact that I'm missing a part I'd give the CF chassis a B- so far... I haven't run it yet so I couldn't tell you if it is any better. I'm especially curious to see if the new steering assembly makes it better or worse. BTW with the hops and the cf chassis it doesn't look like a TB-03 anymore. If I posted a pic and called it a TRF-418 I could probably fool a few people!
You guys don't want to see any pics, do you?
DragonDrop is offline
