Tamiya TB-03
#2206
#2208
After you kicked our butts so bad at TCS....I'm not sure I should share.
The tb04 gear diff pn 51549, eight 2.6mm x 6mm cap screws, whichever TB04 outdrives fit your fancy (51554 are steel), gasket 51553, and the ring gear pn 51255. You'll need to file the pinion shaft for clearance (it rubs on the gear diff case). I replaced the 8x5mm bushings with bearings to try and keep the cases in better shape longer. I shim my outdrives fairly tight so they can't walk side to side. You want the diff to be pretty firm when you get it built, and then bed the gears in when you get to the track by driving a pack through it kind of easy. Guys who set them up too loose seem to have problems breaking them; I have yet to have a TB03/04 drivetrain failure.
It is about 12grams heavier than the ball diff.
#2217
I've got a new to me TB-03 on it's way. I plan on running our local carpet races with 17.5T motor. To maximize downtime I'd like to get the motor and 64p robinson racing pinion/spur on order.
Can anyone recommend a good starting point for the Tooth count of pinion and spur? Thanks.
#2218
#2219
Would that kind of differential be legal in TCS?
http://banzaihobby.com/Blade-Racing-SPR009-TB
