Tekin RS ESC sensored
Hi Tekin thread, is Tekin a good product? Should I buy it? I mean, yeah, it's winning right now, everyone's buying it but I'm not sure if I should, only because someone might beat me later. So how long will your product last in a competitive market? Shoot yourself in the foot and give me an answer please.
There is nothing wrong with bumping up the endpoint.
If they were to implement something like that, since you don't have any problems with your radio, your full throttle float adjustment value would be zero and as a result, the precision of your radio would not be affected.
It is only for RCGT, and even then it is only for our RCGT series which was started last year before any of the mega-timing speedos were around. In the interest of RCGT being cheap and fair, v203 was outlawed for RCGT until the series is over. Most people are running GTBs or Speed Passion speedos that can't even keep up with the SPX's in the series, let along the SPX's trying to keep up with v203 Tekin's.
They were told "anything except v203". I put v200 (the next best option) on Technique550's Tekin, so I don't know what the issue is.
200 will still be quick if set up properly though, you've still got boost and turbo just not as much control over them as you have with 203.
Hey!
I have looked into Tekin and wonder, wich Tekin is the best for 13,5 stock class and modified? I will run both and want the best out of it.
What i can read, do i need to have a computer to setup the ESC? if so, how?
Thanks! // www.andrefossto.wordpress.com
Regional Moderator
Andy- If you are going to be running a motor faster than a 5.5 get the Pro, otherwise there isn't a difference. The Pro is a little taller and heavier though.
I asked the same question a while back. Randy chimed in with the 5.5 rating came from 2WD off road, not 4WD TC and I would be much better off with a Pro.
So I am curious....what is the lowest turn motor you guys (or gals) have run with success with an non-pro RS?
To do updates yes you need a pc,to do timing and rpm changes yes you need a pc,for 13.5 the rs is fine but what do you run in mod
i would guess a 7.5
i would guess a 7.5
