Tekin RS ESC sensored
It is only for RCGT, and even then it is only for our RCGT series which was started last year before any of the mega-timing speedos were around. In the interest of RCGT being cheap and fair, v203 was outlawed for RCGT until the series is over. Most people are running GTBs or Speed Passion speedos that can't even keep up with the SPX's in the series, let along the SPX's trying to keep up with v203 Tekin's.
They were told "anything except v203". I put v200 (the next best option) on Technique550's Tekin, so I don't know what the issue is.
+1 if they can't even tell you what version of software you are allowed to use.... in effect that just says you can't race, which in todays age is just lame where some clubs are finding it difficult to keep racing alive or finding new blood...
(If they have though, then ignore my post).
This question is for the Tekin guys and I'm not even sure you would be willing to answer these questions, but…
Based on the current trend of other manufacturer's ESCs and ESC technology in general, is the RS engineered well enough to last another 12-18 months before requiring a hardware upgrade? Is the current firmware architecture robust enough to take advantage of any operational parameters that needs to be changed? What are some of the current hardware limitations that are preventing the RS from becoming even faster?
What you've done with the firmware is just amazing – and I realize that you'll have to upgrade the hardware some time down the road. Later would be better than sooner!
Thanks!
Thanks!
Super Moderator
Mine didn't work after 3 minutes each run last weekend. Car was ballistic using Schreffler's settings for the beginning of each race then went flat, like it was stuck in 1st gear.
At the end of the day I did the 90% throttle recalibration then bumped it up to 100%. Seemed to fix the problem, we'll see how it works next race. Oh, and my battery was a little low on my transmitter.
Thanks!
Thanks!
Regional Moderator
Thanks!
Thanks!
The current stuff is being tested all the time and keeps getting faster. It is currently the fastest so where are you basing your concern? Tekin is always looking to improve, just because they are on top doesn't mean they've stopped pushing the envelope.
instead of the traditional setting of 0 motor timing and 50 timing boost, has anyone played around with max motor timing and minimal timing boost eg. 10-15?
can anyone see a downside to this setting?
sorry if it sounds like a stupid question,its currently 3 hours past my normal bedtime and brain doesnt function well looking for the extra few tenth's this time of hour haha
Having said that, I have had a lot of success on tight corners (12th scale) with 5º motor timing and 50 timing boost, instead of the full 55 timing boost. When I used 10º motor and 45 timing boost, the motor got hotter for no return on acceleration or speed. HTH
Thanks!
Thanks!
So now we are back on top....
I don't see any major features happening with the hotwire adjustablilty (IMO) now that issue got addressed.
Even if for example the on resistance could be lowered, you wouldnt notice the difference, or get any benefit from it!
The Pro doesnt need any more FETs, it can control any motor out there.
Well I guess the question prior to all of these is... Which "speed control" is beating the Tekin and how are they doing it?
As I posted in another thread, Tekin has essentially released four different ESCs over the past two years - 180, 189, 200, 203 (Did I miss one? I've only read up to page 525). It's not like they put out 203 and they've been improving 203. The difference between 180 and 203 is night and day. Are there any more configurable parameters coming out or is this it? Is this the most we can expect out of this piece of hardware or is there more to come?
What's interesting, is that Tekin implemented what some people were asking for early on. What I haven't been able to figure out, is if Tekin already planned for these parameters to be available in some future release or if they were able to make these paramters available based on the architecture they developed.
But this turbo cutting out thing and having to recalibrate the throttle suggests that there are certain limitations as to what Tekin can reprogram within the RS. Is this a problem from 200 that just hasn't been fixed yet or can it only be fixed replaced by replacing the hardware? I don't know.
So are we at midpoint in the RS' lifecycle or closer to the endpoint? Because as soon as it's replacement comes out, you know what's going to happen.
You know how this goes. As soon as you buy something that's been out on the market for a while, some time in the next week or next month, the manufacturer anounces it's replacement.
All you have to do is up the epa a bit over what it was calibrated for and problem solved. To me, it's a complete non-issue.
That's not really a problem with the hardware or software, it's a radio problem. I can assure you that this has turned up on other speedos at other times but no one ever noticed before because it had almost no effect on performance. Now that you have a timing function that is dependent on full throttle position, it's become more noticeable.
But if you know that there is a floating endpoint problem, in theory, it can be addressed by adding an adjustable range value for full throttle positioning within the firmware to account for the float! But that may sound much simpler than it is to implement.
I hear ya!
Don't blame the speedo for radio problems.
And again, what is wrong with just bumping up the endpoint a bit? This is a much easier fix then changing the speedos calibration routine around, which will only make it work better with radios with poor accuracy, but give less precision to those with accurate radios. I don't want them to put a bandaid on it that is going to hurt the performance with MY radio.
I hear ya!
I will give you an example. Robert at KO says to re-calibrate your radio every 6month, since the KO has a way to calibrate all its endpoint. even at that the radio from my sentry data loger varies teh endpoint by plus or minus 2. but I have seen other recordings that the radio varies by plus or minus 7. i like my ko, and really for me to calibrate the radio to the tekin, I set it at 145 and then bump to 150. that means I loose about 4% of my throttle throw or you have not just created a deadband around full throttle at 4%. that is a lot. just pull the trigger slow and see where full throttle engages and when turbo kicks in. I can do this and not have the triggle mashed to the floor.
How? The only way the speedo can know that you have hit full throttle is from the signal. If it sees a WOT signal, it goes wide open. If the signal it sees is only 98%, it is not seeing WOT. If you don't like it, get a better radio. I have not seen this problem with either my M8 or M11.
And again, what is wrong with just bumping up the endpoint a bit? This is a much easier fix then changing the speedos calibration routine around which will only make it work better with radios with poor accuracy, but give less precision to those with accurate radios. I don't want them to put a bandaid on it that is going to hurt the performance with MY radio.
If they were to implement something like that, since you don't have any problems with your radio, your full throttle float adjustment value would be zero and as a result, the precision of your radio would not be affected.
