Tekin RS ESC sensored
Team Driver set-ups from the Snowbirds?
I know set-ups are gonna be different from track to track, but it'll be nice to see. Also, were all the sponsored drivers using 204?
Small w/ no straight away lots of tight turns.
Throttle Profile: 5
Timing Boost: 47
Turbo Boost: 5
Turbo Delay: .5
Start RPM: 3000 ish
End RPM: 5500
Ramp Delay: 2
Rollout: 74mm
Large w/ 90' straight some technical sections.
Throttle Profile: 5
Timing Boost: 50
Turbo Boost: 5
Turbo Delay: .7
Start RPM: 3000 ish
End RPM: 6500
Ramp Delay: 2
Rollout: 79mm
I will be posting all of the Tq and winning setups as soon as I get them from the guys. I'm sure they're all recovering from the race.
Hey yang, Thanks for all of your help getting people pointed in the right direction. Any new setups for 17.5 1/12 on a tight and large track? Here are a couple that I have liked the last 2 weeks on a small track and large track.
Throttle Profile: 5
Timing Boost: 47
Turbo Boost: 5
Turbo Delay: .5
Start RPM: 3000 ish
End RPM: 5500
Ramp Delay: 2
Rollout: 74mm
Throttle Profile: 5
Timing Boost: 50
Turbo Boost: 5
Turbo Delay: .7
Start RPM: 3000 ish
End RPM: 6500
Ramp Delay: 2
Rollout: 79mm
Throttle Profile: 5
Timing Boost: 47
Turbo Boost: 5
Turbo Delay: .5
Start RPM: 3000 ish
End RPM: 5500
Ramp Delay: 2
Rollout: 74mm
Throttle Profile: 5
Timing Boost: 50
Turbo Boost: 5
Turbo Delay: .7
Start RPM: 3000 ish
End RPM: 6500
Ramp Delay: 2
Rollout: 79mm
here are my current stock and superstock setups. these are pretty good setup for the motor just gear a couple teeth down to start. these are really setup for our track and where the rpms hit and where the speed hits down the straight.
Big props to Tekin on a great performance at the Snowbirds. It pretty cool to see the brand rise up from the dead to become the most innovative speedo company, just like back in the old days!
Is the Tekin software on their website the latest one?
If not can someone send v203 to [email protected]
Cheers
Cheers
Cheers
Cheers
You need to register yourself with Tekin to get their e-mail that connects you up with the V2.03 software. Easy!
Bill
R/C Tech Elite Member
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
I downloaded the software and got a 64bit and a 32bit short cut. Which one do you use?
Open Control Panel. Click on System.
Beside system type it should read 32 or 64-bit Operating System.
Jason Schrefflers Tq and Winning 13.5 Rubber TC Setup from Snowbirds:
Pay attention to his START rpm...this is how he can get away from a 0 delay on his turbo.
