Tekin RS ESC sensored
Ran the RS in race environment for the first time this weekend...man that thing is fast. Had to learn how to drive the car all over again, and even though I was driving a 17.5, had to treat it more like a mod motor, with limited use of WOT.
With that said, I started to feel like the Delay was more annoying than anything. Had to plan for when it would kick in. Why wouldn't it be better to set the delay to 0.1, and control it using your throttle finger. When I hit WOT, I want the thing to go, not wait 20 or 40 ft and explode...
But man, when it goes, it GOES! At first I thought I had a problem, because it didn't seem to be going like I had thought it would from reading posts. Then I realized I wasn't actually pulling the trigger all the way. The first time I did it and it exploded I almost slammed into the boards at the end of the straight...
Can't imagine what this thing would be like with a 5.5....
Nice job Tekin...
Nice job Tekin...
Try more boost timing with less turbo timing and a shorter delay (but NOT .1).
Nice job Tekin...
Nice job Tekin...
try loading a older version and then do a master reset then go back to 203.
You know you can run .1 and even 0 for delay... if your track warrants it. I too ran in the Florida state series this weekend at minnreg and the car was very fast. I took 4th in wgt and could have finished better were it not for my booster shutting down 4 times in the main.
I have both reciever pack and "Notso Smart Boost" in my WGT. When I learned of this issue w/V203-1S, never bothered w/Booster. Let the "Pioneers take all the Arrows"
Ditch the Booster, atleast for now. Several pages back, guys were reporting "Brown outs" with the Novak Booster.
seems it only happens to some. I know several that ran the booster without problem. I however will be ditching it for a rx pack and hoping my rx can handle the voltage.
I got the e-mail.
We have some important information regarding Order # 3383705, which you placed on our website.We are not able to ship your order at this time, but we expect to ship the order in its entirety in 1 week.
If you would like to keep your order on backorder for shipment in in 1 week, NO ACTION IS REQUIRED. You will receive an email update with tracking information when the order has shipped.
If you no longer wish to receive your order, please cancel it. To cancel the order, log into your account at http://www.shopatron.com/account/ . We apologize for the inconvenience.
If you have any questions regarding this order, please contact Novak Electronics at (949) 833-8873 or [email protected].
Thank you very much for your continued business and trust.
Customer Service
Novak Electronics
(949) 833-8873
[email protected]
Customer Service
Novak Electronics
(949) 833-8873
[email protected]
it sound like it may have to go back
Not to "Over Think" this issue, but, to avoid the too high voltage issue that the LiPo reciever packs present, I'm using a Losi 150 mA Nimh pack (Micro-T) w/plug connecter changed, charges in 15 min, wieghs 17 gr,6.5V w/full charge, no regulater required.
To help eliminate some possibilities. Try someone else's CPU/Hotwire set-up at the track. If their set-up works then it's your CPU/Hotwire set-up that's causing the problem.
Or try to update a different RS with your CPU/Hotwire set-up. If a different RS takes the updates without any issues then you can eliminate your PC/Hotwire as the problem.
I had the same problem. Called Tekin support and descrbed what I did, was told that it shouldn't be the Hotwire and I must have disconnected it during the update. OK, I had a second RS to set up and I hard wired the PC to the internet feed, now I have two dead RS ESCs because the second one went. Called Tekin, they said to send both ESCs and the Hotwire in. Did that.
Went to the track, used someone else's Hotwire and it worked perfectly with my computer. What would you guess went wrong?
