Tekin RS ESC sensored
#1021
How does it perform with 100% timing and compared to what? what about temp.? i will go and get my SP 9.5 today...
#1022
I didn't tested it yet. I hope it's dry tomorow so i can test it.
I want as much as possible power.
#1023
If you run sensored only you can have more timing, hence more revs. And in sensored only the timing set in the hotwire has no effect at all.
#1025
Hotwire or RS Pro issue?
Bench testing settings last night. Hotwire sees my RS Pro, can read current settings, can even change firmware. However, after attempting to change settings, I get an error box with "No response from the controller". Disconnect Hotwire, re-connect to Rx. Turn on power switch, servo works, all red LEDS on dim on RS Pro. Reconnect Hotwire, restart Hotwire software, single red LED on bright on RS Pro, flickering green LED on Hotwire and red LEDs dim (like usual). Can see current settings, change drag brake %, apply settings, same error.
RS Pro only gets all LEDs on dim at powerup.
Ideas? Is she dead, Jim?
Already tried uninstalling Hotwire / software. Removed USB entry from the registry, reinstalled s/w, etc. Same No response error when applying settings. Hotwire SW can still retrieve current settings. Tried "Factory reset" with same results. RS doesn't appear to start up.
#1026
Working again
Even though I tried it last night at home on my laptop, I installed the Hotwire software on my work PC, and downgraded the RS Pro from 180 to 178 fw, then upgraded back to 180. Now everything works OK again. I'll have to try changing settings with my laptop before I leave work today in case I need to go through this again.
#1027
#1029
Does .NET not have some built-in utility for detecting the installed version? Perhaps the software could alert us if our .NET is out of spec?
#1030
Bt witch way is the best way to connect a brushed motor?
Where do i get the most power out. 2 wires or with in total 4 wires to the motor?
#1031
If you look at your instructions it shows hot to do it properly. I use a trimmed down battery bar soldered straight to the posts. This requires advanced soldering skills and should only be done if your comfortable. Next best way is to simply jump the s wires together close to the esc and run one of them back to the motor.
#1032
#1033
Oh, and after bringing the RS Pro back from the dead with the downgrade/upgrade trick, the laptop can talk to it fine.
#1034
It will depend on the motor. Some motors have more timing adjustment. I've been using the Tekin that allows up to 24'. So with that motor in Sensored only I'm running my timing at 90. I tried 100 but had to much wheel spin(ie too much power).
So I'd tell you to do the same. If you want more power and top end crank the timing up to max. Watch your temps and make sure you're geared accordingly.
Randy
Randy
RC
#1035
It's been said time and time again. The timing slider in the hotwire is relevant of the sensorless operation of the motor only. When the sensored only mode is being used, this slider becomes irrelevant, just like the push control slider in brushless mode.
