Tekin RS ESC sensored >
Old 07-28-2010, 05:20 AM
  #16021
Default TP1 & Sensor Wire
Is using a sensor wire neccessary when using TP1 Spec Mode (0 timinmg advance) or can I just leave the wire off with no detrimental effects?
Gris is offline
Old 07-28-2010, 05:29 AM
  #16022
hairy's Avatar
Originally Posted by Skitee
It's not the end of the world though, uninstall hotwire 5 then re-install hotwire 4 on your pc and flash 203 back onto the RS.
Thanks but the problem is I can't find on the tekin web site the download for any other versions BUT v208.
hairy is offline
  #16023
macdude's Avatar
Running in sensored mode makes the motor feel like its got more rip. If you run in sensorless mode the motor will feel much slower. When you get into the higher kV motors it doesn't seem to make as much of a difference. But for stock spec racing I would leave the controller in sensored mode. If you want you could also try running in "dual mode" which starts sensored and then runs the rest of the time sensorless. But whenever I have done this with a stock motor the car needs to be geared up significantly.
macdude is offline
Old 07-28-2010, 05:58 AM
  #16024
Even in TP1 stock spec mode with 0 advance & a 21.5?
If not, it would be nice not to have to worry about the sensor wire.
Gris is offline
Old 07-28-2010, 06:19 AM
  #16025
JCarr's Avatar
Originally Posted by FLAT OUT
Any one ??
Yes when you recal. you should turn both throttle and brake endpoints down to 90 and then back up after you finsh the calibration. That will ensure you get full repsonse.
JCarr is offline
Old 07-28-2010, 06:20 AM
  #16026
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by hairy
The MSRA rules state specificaly (sp) v200 ONLY! so no go for me, just wish that was known before hand that I would lose the progrma all togehter. rather dissapointing!
Just delete the V208 and reload the 200 then. Email Randy and ask him how to properly remove it from your hotwire. It can be done and you will be legal for your spec class at your home track. You aren't "STUCK" with 208.
STLNLST is offline
Old 07-28-2010, 06:37 AM
  #16027
hairy's Avatar
What i am saying is that the program does not exist any more on the tekin web site, so there is no program to reload for v203 or 200.
hairy is offline
Old 07-28-2010, 07:04 AM
  #16028
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by xray09ACT
when you connect the dubi-whacker into the thingi-majig and click on next a few times and then ok, a black box pops open. this then runs around chasing the old hotwire program and kicks it out of the computer like a drunk out of a bar who has no money. after wiping up the mess it installs the new program onto the computer so when you plug the dubi-whacker into the thingi-majig back in it will install 208 automatically
I understand all that! My point (that everyone seems to be missing) is that my computer never had the file. Unless the Tekin Hotwire 4 Uninstaller automatically removes it (I did not look until after I had uninstalled the Hotwire 4). In which case I don't understand why Tekin has you manually removing it in their instructions.
M-Technic is offline
Old 07-28-2010, 07:06 AM
  #16029
JCarr's Avatar
I think that is just a vista deal. I don't think it is an issue in any other version of windows.
JCarr is offline
Old 07-28-2010, 07:08 AM
  #16030
M-Technic's Avatar
Alright, thanks. That's kind of what I was guessing. Although they have the same instructions for Vista & 7.
Old 07-28-2010, 07:38 AM
  #16031
BCbud's Avatar
Trader Rating: 37 (100%+)
Originally Posted by BCbud
Good day!
Ever since I installed thr RS into my touring car, Th RX battery low warning and beeping are coming on on my Spektrum DX2S. The GTB that I took out of the touring car and put into my pro 10 car dosn't do this and I use the same raido with both cars. This will happen with the car and raido turned on but not being used, just sittng there. Any ideas?
Thanks Neil
Well I thought it was the servo but it wasn't, any ideas? I am thinking about using a voltage regulater but I don't understand why. I have a small esc sized fan on the motor, a personal transponder, servo and a temp senser running of the rx, is that too mutch?
BCbud is offline
Old 07-28-2010, 07:48 AM
  #16032
TrevCoult's Avatar
Removing the file has not been necessary since 203/HotWire 4. No need to worry about it.
Trev
TrevCoult is offline
Old 07-28-2010, 08:19 AM
  #16033
M-Technic's Avatar
Trev
Cheers.
Old 07-28-2010, 10:09 AM
  #16034
I've run my 21.5 in dual mode, and in sensored mode with no timing. It has absolutely no top end whatsoever in dual mode. You definitely want to run sensored with a wire. Also, just because you're not adding timing with the ESC doesn't mean you can't add timing with the motor endbell. But you can only do that in sensored mode.
-Mike
grippgoat is offline
Old 07-28-2010, 10:28 AM
  #16035
rcguy76559's Avatar
Trader Rating: 22 (100%+)
i got a tekin rs with a novak ballstic 17.5 set at N mark i am going to run 17.5 spec class they say no boosting or timing added what do i set that at on esc. do i put it at 0. kinda confused because it starts to cog really bad sometimes at 0. Does the motor timing needed to be added to the amount you give it or does it over ride the motor. I would search this but search been down for like 4 days now. pm me if you like.
rcguy76559 is offline
