Tekin RS ESC sensored >
Old 10-20-2009, 03:39 AM
  #7711
it's hard to say how long the straights are but play with the gearing a bit.
But the track looks very fast.
mikky32 is offline
Old 10-20-2009, 05:19 AM
  #7712
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
what are most of you using 48p or 64p in your cars
20 SMOKE is offline
Old 10-20-2009, 05:24 AM
  #7713
48p
mikky32 is offline
  #7714
mazmo's Avatar
48p in 10.5 onroad TC
mazmo is offline
Old 10-20-2009, 06:27 AM
  #7715
Regional Moderator
CarbonJoe's Avatar
It seems like most asphalt guys use 48p, while most carpet guys use 64p (at least in the US).
CarbonJoe is offline
Old 10-20-2009, 09:56 AM
  #7716
Paul Sweeney's Avatar
Location: Somewhere Back Stroking Under The Verrazano Bridge
Originally Posted by oze
Where can buy this ESC? Seems to be out of stock everywhere?
AMPDRAW Has It
http://www.ampdraw.com/product/10064...-(5-turn-limit)
Paul Sweeney is offline
Old 10-20-2009, 10:42 AM
  #7717
Micro-E's Avatar
Hi, I am looking for input on my RS setup from any 17.5 experts to see if I am in the ballpark for a v200 setup. I ran my car first time with v200 this weekend it was slower on the back straight, but more ‘snap’ in the infield sections than with 198.
Previous v198 Setup: TP=3, Boost=30, Motor=Tekin 17.5 at 0*, FDR 4.45, temp at end=~130 (I did quite well with this setup - took the win in my class)
New v200 Setup: TP=3, Boost=15, Turbo=Max, Delay=1sec, Motor=Tekin 17.5 at 0*, FDR 4.45, temp at end=~118
I have been following this forum, and have been reading people have actually gone shorter on gearing with v200 and reduced the boost, so I left the 4.45 and dropped to 15. I was getting smoked, so I lowered FDR to 4.33 and it was better. Temp went up to ~125.
Track: as a few tight infield sections, but more flowing, back straight is ~170’. (Picture Attached)
Given the track layout and length of straight, what are your thoughts? What would you change? Just add more boost? Would gearing up start killing torque?
Micro-E is offline
Old 10-20-2009, 01:03 PM
  #7718
poochy's Avatar
Default help
i installed the v200 and the tekin software is not detecting that version-i am not able to see a 200 version to be upgraded to. plase advise.
poochy is offline
Old 10-20-2009, 01:18 PM
  #7719
I have had the same problem, seems to be a Vista thing runs fine on XP.
Jason
jasonb is offline
Old 10-20-2009, 01:21 PM
  #7720
poochy's Avatar
im using xp.
poochy is offline
Old 10-20-2009, 02:01 PM
  #7721
im using xp.
Did you unload the old version from your computer 1st?
SRW141 is offline
Old 10-20-2009, 02:52 PM
  #7722
20 SMOKE's Avatar
did you try going 20 on the boost to help in the middle of the straight and drop the delay down to 0.5 to finish the straight.125 deg is nothing you still have some room to play
20 SMOKE is offline
Old 10-20-2009, 04:37 PM
  #7723
Trader Rating: 29 (100%+)
Default v200
How do you get the V200 update?
jct108 is offline
Old 10-20-2009, 05:39 PM
  #7724
20 SMOKE's Avatar
vegas 200 http://www.rctech.net/forum/6476509-post7588.html
20 SMOKE is offline
Old 10-20-2009, 09:23 PM
  #7725
Moderator
Clegg's Avatar
Just want to add that Hotwire v200 works perfectly on my netbook (HP 110 XP) running Windows 7 Pro x86. In case anyone was worried about compatibility with the new OS.
Clegg is offline
