Tekin RS ESC sensored >
Old 09-05-2009, 11:27 AM
  #6826
avrcguy's Avatar
Can someone offer a good setup recommendation for the new software with "turbo boost"? It's in a b4, and will be running on a medium to high grip, medium sized track.
Thanks.
avrcguy is offline
Old 09-05-2009, 11:41 AM
  #6827
Trader Rating: 31 (100%+)
Originally Posted by Cpt.America
Brian,
I do something very much like that with my 3PKs.. I calibrate at 90 and reset to 100, but for a different reason. For some reason, some of us have an issue where the turbo feature literally dissapears after 4 or 5 laps, every time we run. I can only speculate a floating end point. Overshooting the calibrated spot by 10 gives turbo the entire race. I think this would be a good idea (like you are suggesting) even if you DON'T have this issue, just in case you just BARELY wiggle your finger or something, making you lose turbo when you didnt want to. Maybe 120-150 is a little extreme... but I think its a good idea.
The Capt
I am glad you guys are experiencing this too. I have noticed that turbo is temperamental seems to be gone after first few laps. I also have a 3pks and have been calibrating at 120 for throttle and brake.
jjdoyle is offline
Old 09-05-2009, 03:19 PM
  #6828
lol, cheers, dont generally hit that much...
rc
prodriver is offline
Old 09-05-2009, 05:04 PM
  #6829
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Calibrate at 120, then increase to 130-135. That should do the trick.
Cpt.America is offline
Old 09-05-2009, 05:35 PM
  #6830
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I think as long as you go over by 10% of what you did your setup at will be fine.
liljohn1064 is offline
Old 09-05-2009, 06:02 PM
  #6831
vazzo's Avatar
Trader Rating: 101 (100%+)
Just a quick note to let you all know that the hotwire software works perfect with windows 7 straight out of the zip file. I didnt have to make any modifications at all.
vazzo is offline
Old 09-05-2009, 06:54 PM
  #6832
Fastforward's Avatar
Guys-
I am having trouble with "radio calibration". The speedo will recognize neutral and full throttle, it just won't recognize the brake end point.
I have tried opening up the neutral dead band in the program, radio epa's and even reversed the throttle servo in the radio. Noting works, it won't recognize the throttle end point.
Transmitter is Futaba 3PM 2.4ghz
Suggestions?
Fastforward is offline
Old 09-05-2009, 10:42 PM
  #6833
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Team Pink
You are going to have to get pass me first my friend. And trust me that is not going to be easy.
Randy would like it if we both crossed the line at the same time and for the first time in rc history have the exact same times
Thanks to rocketron for all the info. Time to go have some some the next time out and put any radio issue's to rest.
STLNLST is offline
Old 09-05-2009, 11:32 PM
  #6834
LOSI123's Avatar
Trader Rating: 63 (100%+)
LOSI123 is offline
Old 09-06-2009, 12:14 AM
  #6835
Originally Posted by LOSI123
Randy:
Just letting you know that i tried my rs pro with my tekin 17.5 motor and with dual mode, low timing, high timing, all different neutral widths, different ver's of software, different throtle profiles, putting all radio setting back to default, and re doing the radio to esc calibration heaps of times, and a differnt sensor cable, all to no joy.
I take it that the RS just coggs very slightly on first trigger input at low speeds, compared to my other brand esc's.
Try a different motor.
Old 09-06-2009, 12:48 AM
  #6836
LOSI123's Avatar
LOSI123 is offline
Old 09-06-2009, 01:01 AM
  #6837
2wdrive's Avatar
i tried dual mode some time ago. It never cogged with me but one advice is to go sensord. It is way faster then dual mode in onroad applications.
2wdrive is offline
Old 09-06-2009, 01:54 AM
  #6838
cyanyde's Avatar
Randy:
The RS is one of if not THE smoothest esc I've ever used and have never faced any cogging issues. Neither did most others in this forum. You may have a bad apple. Get that sorted with Randy.
cyanyde is offline
Old 09-06-2009, 04:35 AM
  #6839
Originally Posted by klassicks
Hello, can anyone tell me how much is the peak current for Tekin RS Pro?
ex: -ORCA VRITRA generate 360A,
-LRP Tc Sphere generate 400A,
-Tekin RS Pro ??
(correct me if I'm wrong)
No one can help me on this??
klassicks is offline
Old 09-06-2009, 05:27 AM
  #6840
vazzo's Avatar
Thats top secret, highly classified information you're asking for there.
vazzo is offline
