Tekin RS ESC sensored
#5146
Twelvegauge... it doesnt look like you are actually reading the responses you are getting here. Try these steps....
1) Clean out the inside of your motor. Sounds like you might have some debris
2) Download the latest firmware from tekin's website, 1.98
3) Install 198 on your PC (you have to completely uninstall the old version first)
4) Upgrade your ESC using the hotwire
5) RECALIBRATE YOUR ESC TO YOUR RADIO <<<important step
6) drop the timing on the endbell of your motor to something like 10 degrees
7) Now that you are upgraded and recalibrated, go through the settings in the hotwire.... I would start with these
Sensored only check box
Timing boost - 20 (this will give you a total of 30.. 10 on motor, 20 in hotwire)
Throttle profile - 5
Current limit - off
motor type - brushless forward and brake only
Current limit - off
#5149
i had the same problem the other day
go to your end point adjustment set break to 80% throttle to 100%
the center all your trims
then calibrate
then calibrate
#5151
if you still dont get it turn on the car with radio off
you should have all the 8 leds solid (no signal)
then turn your radio on, you should get 4 led on at one end (pull the throttle ) and the move from one end to the other ( not seeing neutral )
press and hold mode you will then hear a chime then follow instructions
If it still not working when in step one full throttle adjust endpoint till you hear chime
#5152
I tried setting my trim to 0 and I have a JRasorus xs3 do I have to set all the setting to 0 or just the trim? In the TBD mode the throtle is L/F 20% and the break is R/B 65% the mix is 125% and throtle forward is 100% and break is 100% and I have recalibrated this thing 6 times in the past hr.
#5153
#5154
Thank you very much for this fast and...concise answer.
I am from the french-speaking part of Switzerland.
#5155
+2 yup,if once you find the right setting,u have power esc,is true ! u away use tekin product only,if u buy other esc,u every buy newest esc few months,i very happy have speedo rs pro........
#5156
Make sure that you throttle/break trim and sub trim is set to zero, if the trims aren't zero then it interferes with the RS trying to find neutral.
#5157
Hold on,
What 4 led's are flashing when the unit is on? When the RS is unplugged from the receiver you should see ALL led's flashing.
If however when it's plugged in and you see 1,2, 6, 7 you've either got the wrong motor type selected OR the motor may have an open winding.
Did this motor get run hot?
I need to know which led's are shown?
#5158
you might not have recalibrated the throttle brake correctly...
put it in calibrate.
wait for it to find neutral then it beeps 3 times
pull the trigger for forward wait for 3 chimes then push the throttle forward to brake and wait for the chimes
#5159
Hold on,
#5160
I have 2 RS Escs just loaded the latest software available and not so impressed. If i was honest car handling was better with the 189 setting . A number of cars were been blown away by the LRP SPX in stock 10.5 1/12th carpet racing.
Seriously thinking of purchasing an LRP SPX unless i can get this set to my satisfaction maybe the never ending upgrades will fix the problem roll on profile 200 if it ever hits the street.
This will be my last attempt to get what i want before i decide to part company with the RS . Hope it is solved as i really like the TEKIN products but it seems we are been used as trial bunnies . There have been so many upgrades (some of them duff releases) im a little bit dissalusioned.
RANDY are you listening can you solve my problems.
We allow the user to run backwards software should you choose to as their are different feels and some prefer to use what they know.
Even with 198 software I can get the RS to run right there with an SPX on a track with average sized straights. Once the track gets longer and straight away length grows over 100ft the new 200 software will be needed to compete. Not only will it compete but it often will surpass the "other" speedos being used right now.
If you or ANYONE else needs setup help please contact me:
[email protected]
Yahoo IM: TekinTeamMgr
More often then not someone has had just one setting or a combination that of settings that has caused their setup to be off.
