Tekin RS ESC sensored
#4726
Well just got back from a weekend's racing, first one with a Redline motor as I have been running a Novak 13.5 on my RS Pro. The brakes on the Redline are about x3 of the Novak, I could actually stop!!!!
Secondly I had great speed on the infield, staying with the TQ man who runs GM, but was getting beaten up 2nd half of the straight.
Roll on 1.99..........................
I was faster in the infield and straight. The only problem was the car.
My car was running like it was on ice.
Lost my rear each time and when I solved the problem, I hath to much grip in the back. The track was cooling down.
The day before was better. setup was good for the track temp.
But yesterday the track was hot very hot.
#4728
Have you tried to recalibrate your esc after updating the software? If it's found nuetral it should arm and drive the motor unless something else isn't set properly which it looks like it is.
You don't have a VC set though so I'm assuming you're running round cells?
#4729
One factor that people with lack of brake strength have in common so far is tha the rollouts or FDR's are HUGE compared to us here in the states. Since the gearing is so tall it's harder to slow the car.
We are in working on an adjustment to compensate. Often times the brakes are turned down because they're too strong. I remember the first time I slammed the brakes in testing I stripped a spur!
We are going to make it right...
#4730
From my understanding, both the rs and pro come with a 200mm sensor harness included, a shorter 100mm version is available as a seperate item
(I got the 200mm included with an rs pro/13.5 combi pack).
TT3810 is the 200mm harness, TT3811 is the 100mm.
hope that helps
hope that helps
#4731
Hi, i up loaded the latest version onto my esc and i had and extra, Turbo, i read up on it and it sounds great i used it and wow made a big difference. I was wondering if anyone else has used the latest version, and if so how much did you come down in gearing? Or has it been cooking motors? Mine came off fine after a 5 min race but i thought that running a lower gearing mght also help.
Kingy
Kingy
#4732
Had my first race tonight, and wow my car was quick. I was racing with 13.5 turns and i was easily matching with most of them down the straight and out of corners. Now if only i could get my car set up a bit better
#4733
Just got my Tekin RS. Is the capacitor for the battery terminals totally necessary? I have seen some people run without it...
#4735
do install the capacitor !!
Its supplied for use with the esc so therefor is part of the esc.
In mod class its suggested to add 1 more cap.
#4737
Kingy
Kingy
#4739
I wish I had some 'free' drivers nearby!!!!!
#4740
I'd hate to be Randy right now trying to keep it under control. It sounds like there is a lot of pressure out there for people to get their hands on the test version with the SPX out there.
Oh well, I guess that's why he gets paid the big bucks
