Tekin RS ESC sensored
#3572
If you put the cursor over the function, it will tell you what it means. Reverse motor will make the motor run backwards. Kinda like wiring a brushed motor backwards. Its for cars that mount the motor in an opposite way.
#3574
Well updated my Tekin RS Pro to 198. No issues here. I uninstalled my Tekin Hotwire off of my Acer One netbook from the Control Panel. Then I installed the new software. Then hooked up my esc to the USB, started up the program. Then applied the new 198 to my 194. No issues.
#3575
#3576
Looks like we messed up on the 1S checkbox in the final rev. It is setting 1S in the controller even thought it is not showing it when plugged back in to the hotwire. Unfortunatly that means you cannot uncheck the 1S and get back to normal.
If you select 1S and save settings you have to do a factory reset on the unit to get it back to normal operation.
Chris (hotwire engineer) is gone climbing mountains in Canada this week so we might have to pull this new version off the web until he returns and it can be fixed. It appears fully functional in all other areas. Sorry for the mistake
Tekin Prez
Tekin Prez
#3577
i cant say anything about 1s functionality... otherwise 198 worked well for me.
May I suggest however (again ) to drop the nice looking graphics in the UI to a more functional one that easy to see what you have selected and easier to control.
Is it just me that when i put the mouse on the slider it's extremely difficult to move more than a couple of points at a time? you have to point to it again and click and drag again to move a futher couple of points...
granted u can use the up down arrows, etc...
g
g
#3578
Tekin Prez
Tekin Prez
#3579
#3580
Over the last week I've installed my new RS Pro and Redline 10.5, installed the 194 software (Thanks Randy) and read ALL 235 pages of this thread!
This is my first brushless system and I'd like some advice please. Any advice for boost/timing set up and gearing for my home track would be very much appreciated.
It's 160 x 90ft asphalt in a TC with lipo. With a brushed 19t motor I'm generally geared between 4.8 - 5.0 if that helps.
Same question (same combo, RS + Redline 10.5) for 5 cell racing.
#3581
Similiar answer:
I'd go out with 10 on the motor and 20 on the boost to start out. Keep your current FDR and run it at race speeds for half a run. Pull it off and check motor temps making sure they're in line. If they are quickly finish the run and temp the motor again. Make a gearing adjustment or timing adjustment based off of that.
If the motor comes off super cool, go up a pinion. If the it's close compare speeds with others and make a call there. If you decide to add more timing make sure to drop a pinion for every 3-5 on the timing.
Always check motor temps after a change.
#3582
g
g
(even though it looks good)
#3583
Just figured it out if anyone else has this issuie go to windows help and download .netframework update....fixed immediately...
#3584
#3585
JL, keep your rollout and go with 5 on the motor and 20 on the boost to start out. Check motor temps and make a gearing adjustment based off that.
Most guys on the team are landing with 5-10 on the motor and 20-30 on the boost. Total timing between the two is going to land around 30-35.
Also,
New software posted on the website:
http://www.teamtekin.com/hotwire.html
Also,
A few hours at the track today had my car pretty much up to speed with the quickest guys at my track.
I kept boost on 20 and ended up with 10 on the motor.
At the same gearing, would 25 on boost and 5 on the motor give me a little more zip out of corners and a little more rpm on the straight?
