Tekin RS ESC sensored
#3376
My esc goes dead by itself. No LEDs on the ESC. Servo went dead as well. It comes back on out of the sudden again.
I have checked and cleaned the receiver, checked the battery connection but still dont know the root cause.
Can someone shed some light?
FYI, i am using 3PK with spektrum micro rx.
Thanks in advance.
Thanks in advance.
#3377
first thing I'd check is the plug... make sure all three wires are fully seated in the black plastic plug. Sometimes they can work loose and then make intermittent contact with the pins in the receiver.
If that's not it, check the wires where they're soldered to the positive and negative posts... a bad solder joint there can cause intermittent shutdowns.
#3378
#3379
Shop Owner
i have the hotwire it is no problem,
our track details are here http://www.bumodgp.com/pist.asp
total track length is 350 (1148 feet) meters , we have 2 straight first 40 meters (131 feet) and second 70 meters (229 feet)
#3380
but the thing is we use lipo 7.4 v and i will use 4 turn motor, don't you think that it will be very fast, i am scared to damage the esc.
#3381
R/C Tech Elite Member
Thanks in advance.
Thanks in advance.
#3382
What you really need to do with mod motors is to put a fan on the chassis that is blowing at the posts of the esc. The posts will get very hot and so will the wires and cap on the posts and everything they connect to. Even the motor wires get hot.
Not something you want to be doing for a long time that is for sure.
When the esc gets hot i noticed a drop in performance. You really need the fan.
Next week i will have a race and will see if the fan is doing it's job.
#3383
I drive an rs pro with a novak 4.5t with lipo's in a pro10.
also randy said the same thing and send a picture to how to place fan on tha chasis. please inform when you put the fan, if it's doing its job.
also my concern is we are doing the races openair, and in turkey we have very high temperatures in summer time.
#3384
Has the brakes been worked on in this build? With my old 3PJS controller I've always struggled having enough brakes but in this last build the brakes seem a lot stronger just during the ESC setup. I'll be testing the car in a few hours so will see if the brakes are indeed stronger.
#3385
How light must i gear my car? i started with 4,7 with full boost.
Now i drive 5,4 with 23 boost and i feel that i can go lighter.
I'm now faster than i was in the race so i think that next race will be even better and my lap times will go even faster.
#3387
Don't be scared to gear down lower than you may think it "right."
We did some testing at Speedworld Raceway where the Reedy Race of Champions is being held. IT has a 160' straight. We were using a radar gun to measure top speeds also. We found that we could drop from what the "normal" fdr of 5.0ish was all the way down to 5.8 depending on the timing setting.
For the record, highest top speed posted was a Tekin RS Pro and Tekin Redline with a 13.5 at 39mph(Jason Moberly). We didn't stay with this setup as it did get hotter than we'd like. We did drop gearing substantially and found a good setup for this track.
Point is that every track is different, layouts are different. Lap times are what counts.
#3388
Randy you have pm!
#3389
randy i you got emails ,pm
desperately need the new software...
#3390
Guys I'm working on it right now. I've got a few hundred emails this morning so bear with me please.
