Tekin RS ESC sensored >
Old 05-22-2014, 04:50 PM
  #23356
Originally Posted by Tekin Prez
The newest software posted on the website takes care of this issue. Update your unit to version 250 and you should not ever see impact button pushes.
Sounds like a typical day at work. "The machine has a mechanical problem. Can you fix it with software?"
Kevin Marcy is offline
Old 05-23-2014, 02:30 PM
  #23357
Team Tekin
Randy_Pike's Avatar
Originally Posted by Frank Hodits
I have an older RS gen1, original hotwire, and original redline 13.5 (all of this was purchased new in the begining of 2010). What is the newest hotwire/vegas version i can use?
Also, what was the stock endbell timing that came on my motor when new? It looks like it's adjustable from 0-24 degrees.
223 for the RS Gen1 esc.
Stock motor can timing is generally set to 12 degrees.
Randy_Pike is offline
Old 05-26-2014, 11:14 AM
  #23358
Frank Hodits's Avatar
Where do I get 223? It seems like only 250 is online now. Also, what about the hotwire 1.0?
Frank Hodits is offline
Old 10-01-2016, 07:03 PM
  #23359
macdude's Avatar
Default 255 Where is the new specs listed
I see that you have finally added drive frequency control. Which is awesome, but I see no info on the actual numbers. I am trying to figure out what I will run for the season and this is on my list again. But with no data it's hard to make a decision. So anyone out there with the new version of the software want to let me know what the drive and brake frequency values are that would be great.
macdude is offline
Old 10-02-2016, 05:57 AM
  #23360
You need to got to Tekins website. there is full explanation of DF and BF on the breakdown on the 255 update. Bottom line you have more linear control of those settings sensitivity depending on the feel you like for your car/truck.
freebird is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
