Tekin RS ESC sensored >
Old 04-17-2012, 06:55 AM
  #22531
Default boost vs FDR
Hello,
I'm running a RS with firmware 212 with a Revtech 17.5. I'm running boosted but I'm unsure of my settings.
I've been told when running boosted my FDR should be between 6 - 7. That's what a few of the faster guys are running. However, the only way I can keep up with the rest of the pack is with and FDR around 4.6. The car was too slow when running higher FDRs like 6.
My settings are full boost, no turbo, thottle profile 3, sensord only. I also have two ticks of timing in the motor.
Our track has about a 100' straight on it.
Could I be over timing the motor? What else could I be doing wrong.
Any help would be greatly appreciated.
AnthonyN is offline
Old 04-17-2012, 07:29 AM
  #22532
mazmo's Avatar
Originally Posted by AnthonyN
Hello,
I would add some turbo, say 15 degree wih FDR around 5.5
Here is my set up for 17.5 boosted:-
Motor Duo2 timing 12 deg
Boost 53 start 5,000 end 10,000
Turbo 15 delay 0.35 ramp 3
Cheers
Alan
mazmo is offline
Old 04-17-2012, 07:35 AM
  #22533
wingracer's Avatar
Trader Rating: 24 (100%+)
Going to run some mod TC this weekend. Anyone got a ballpark FDR for a boosted 10.5 on a fairly long but tight outdoor asphalt?
wingracer is offline
Old 04-17-2012, 07:51 AM
  #22534
mazmo's Avatar
About 8.0 depending on total timing (say 72 deg)
mazmo is offline
Old 04-17-2012, 08:11 AM
  #22535
Team Tekin
Randy_Pike's Avatar
Default 223 is ROAR aproved
Hey Guys,
In case you didn't catch it on FB yet, 223 is Roar approved.
Randy_Pike is offline
Old 04-17-2012, 09:58 AM
  #22536
Buckaroo's Avatar
Hello,
Be careful, the Rev has a nasty reputation because of it's habbit of going POP with even mild boost/turbo profiles. If you're going to stay Trinity, the D3 responds MUCH better to boost.
Buckaroo is offline
Old 04-17-2012, 06:02 PM
  #22537
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Randy_Pike
Hey Guys,
So that there's no misunderstanding, is it correct to say that "LockOut" Spec Mode in 223 is now the *only* approved non-timing profile for the RS/RSPro? Is 212 now "unapproved"?
PDR is offline
Old 04-17-2012, 07:17 PM
  #22538
Odin544's Avatar
Trader Rating: 93 (100%+)
223 has the same blinky mode as 212. It has an additional lockout mode. I would assume its up to the race organizer as to which would be required.
Odin544 is offline
Old 04-17-2012, 07:27 PM
  #22539
PDR
PDR's Avatar
It may be too pedantic, but 212 does not appear on the approval list now. Does that make it no longer legal for an event that uses this list? It's not a big issue for me - upgrading to 223 is easy, but I can see that some racers could get caught out by a scrutineer looking for 3 blinking lights vs 2 (or vice versa).
PDR is offline
Old 04-17-2012, 07:32 PM
  #22540
Trader Rating: 16 (100%+)
That is now what the ROAR website says. Only mentions 223.
Still Bill is offline
Old 04-17-2012, 07:47 PM
  #22541
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Hey Guys,
I know my favorite speedo made the list. Did yours? I see a few speedos missing!
http://www.roarracing.com/?page_id=737
hanulec is offline
Old 04-17-2012, 08:18 PM
  #22542
Team Tekin
Randy_Pike's Avatar
I see no reason why 212 would not be legal. From the looks of it that page is limited to so much text in the "notes" section.
223 has both the 212 led 3 and 5 blink as well as "Spec Lockout" which blinks led's 345 when applied. Once in lock out the user cannot switch the timing profile setting using the buttons on the unit. He/she MUST use a hotwire to take it out of spec mode. This should help race organizers and tech officials.
Yes my favorite esc made the list
Old 04-17-2012, 09:13 PM
  #22543
ByteStream's Avatar
I'm not sure how you could assume 212 would be legal? as there is no mention of it anywhere on that page.
Looking at that page, under the Software Version section, a couple of other speedo manufacturers have multiple version numbers allowed, Tekin only has one version listed - 223.
In addition under the Notes section it explains how to tell if it is in no timing mode and that LED 3,4,5 will be on and blinking. 'Locked' is a Tekin specific software function. It does not say only LED 3,5 should be on.
So if I was a race organizer, I would print that page and go straight off of it .. the version must be 223 and LED's 3,4,5 must be flashing.
From that page, assuming 212 is legal is like assuming 208 is legal, which it is not.
ByteStream is offline
Old 04-18-2012, 05:02 AM
  #22544
jsr555's Avatar
Trader Rating: 18 (100%+)
Cheers
Alan
Pardon the silly question, but the 12 degrees of timing on the motor, is that one notch on the motor can.
jsr555 is offline
Old 04-18-2012, 05:41 AM
  #22545
mazmo's Avatar
Each 'notch' is equal to 8 degrees of timing, so 12 deg = 1 and a half notches.
mazmo is offline
