Tekin RS ESC sensored >
Old 02-21-2012, 11:32 PM
  #22126
Pro10noob's Avatar
From what i have know from Tekin is that after you update the firmware all settings must be set to how you want them as it is been set back to default.
Also you need to recalibrate ESC to transmitter.
That is why there is no chime(when all is ok)
Also when no chime is present after recalibration,check sensor wire and esc wire to RX.
Had that same problem with a Tekin of a mate of mine.
It did work on my RX but on his it didn't.
For some reason he had a poor contact on one of the signal wires to the RX.
Replaces servo wires to ESC and problem was gone.
regards Roy
Pro10noob is offline
Old 02-22-2012, 04:35 AM
  #22127
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Originally Posted by PDR
Just make sure you have the sensor cable plugged in properly as well. When you say no throttle, do the lights on the ESC go up and down, but no motor action?
I applied 222 yesterday and noticed that I had to check every setting in Hotwire - virtually all had changed, including motor type.
Lights go up with full throttle and back down when off throttle. I run stock so both lights are blinking properly. I synced radio a few times. Checked my settings. Still motor does not move. I have steering and it appears throttle is working. When I sync the radio, there is no chime. ????? I'm confused and very frustrated.
I have tried 3 different sensor wires and 3 different motors.
Jamison R is offline
Old 02-22-2012, 05:00 AM
  #22128
First, have you actually re-calibrated your transmitter ? Sounds to me like this hasnt been done. Hold the MODE button for a few seconds, you will hear a chime then bleeps, on the next chime pull full throttle and hold it, bleps again then at the chime pull full brakes and hold it, again bleep and at the chime let the stick go to neutral. It will bleep then chime, then do a long chime indicating its all set. Try then, does the motor spin ?
If it does not then revert your speedo back to 212 using the hotwire program. Once reverted upgrade it again. Once done then do the abovge setup again and test, does the motor move ?
If it fails to, take it back to 212, run the calibration and test, does the motor move now ?
Let us know
Jo90uk is offline
Old 02-22-2012, 05:24 AM
  #22129
Jamison R's Avatar
Smile
Let us know
I have re calibrated my radio 20-30 times. There is NO CHIME. I have reverted. Back to 212 tested, did not work. Went to 222 again, did not work. Thanks for your reply, but I have tried everything you posted and tried different motors, sensor wires, and even a new reciever.
Old 02-22-2012, 05:50 AM
  #22130
Pattojnr's Avatar
Trader Rating: 19 (100%+)
this may be a silly question, but some one who had similar issues to yourself, his motor wasnt set right. he had it on Brushed forward. once the setting was set right to brushless forward, his chimed. a long shot, but basics.
Pattojnr is offline
Old 02-22-2012, 05:56 AM
  #22131
Jamison R's Avatar
It's on the brushless forward setting. Guess it needs to get sent back to tekin. It sucks to have to pay the 80 dollar service fee due to uploading 222.
Old 02-22-2012, 06:47 AM
  #22132
macdude's Avatar
Ok here is what happened to me a couple of times that I have helped people update. Update the firmware again. When the update finishes and the ESC has all the defaults, unplug it from the hotwire and calibrate it to the radio.
IF THIS WORKS it should chime.
The problem I had was that if I adjusted the settings after the update but before calibration with the radio, then the motor type would be wrong according the ESC lights. Even though when I plugged it into the hotwire it was on the correct motor type. I even tried changing the motor type and it still would not work. The lights would move up and down like you are describing, but I also had the blinking lights that indicated incorrect motor type.
macdude is offline
Old 02-22-2012, 06:55 AM
  #22133
Team EAM
Trader Rating: 79 (100%+)
Tekin rs just downloaded 222, now I have no chime and no throttle. I synced to radio. Any help appreciated
Is this in a 12th or WGT? If so no chime but blinking lights is usually a sign of low voltage from a receiver pack or battery. If the RS doesnt see high enough voltage you'll have steering but no throttle and it wont beep.
EA
EAMotorsports is offline
Old 02-22-2012, 07:05 AM
  #22134
ByteStream's Avatar
Originally Posted by InspGadgt
Where's the video talking about the RSx? Is there one shown on the video?
Looks a little bigger than what people are use to ..
ByteStream is offline
Old 02-22-2012, 07:15 AM
  #22135
I had the same thing happen to me.
I had forgot to reset my brakes on the radio to 100% before the sync. after correcting this it worked fine
GW
light is offline
Old 02-22-2012, 07:21 AM
  #22136
avs
avs's Avatar
i believe that if there is no chime, then it isn't arming, which can depend on it finding neutral.
when i updated to 222 i noticed the neutral width was set to a huge value, and put it back to 20 which has worked for me before.
i also noticed it was difficult to get it into calibration mode on the first try, but got it to calibrate after turning it off and back on again.
i don't know why there would be any permanent damage, so you might be best off by reverting to 212 and then install the 212 hotwire version and be back where you started.
avs is offline
  #22137
nmdesertracer's Avatar
Trader Rating: 59 (100%+)
GW
+1 did the same thing.
nmdesertracer is offline
Old 02-22-2012, 07:41 AM
  #22138
bukil's Avatar
Trader Rating: 39 (100%+)
This happened to me on the older versions of Tekin. I found out that my cap somehow got unsoldered. When I soldered it back, everything went fine including the chimes. I'd check this first before sending it out.
Hope this helps.
bukil is offline
Old 02-22-2012, 07:56 AM
  #22139
metalracer2's Avatar
Trader Rating: 20 (100%+)
it does look a little bigger. probably around the same size as the orion.
metalracer2 is offline
Old 02-22-2012, 08:17 AM
  #22140
Jamison R's Avatar
I have tried all above suggestions. It is 2s touring car. Still no chime. I replaced the cap, checked and double checked wires. Checked brakes and neutral width. Reset to factory default and calibrated to radio etc etc. still no chime. This is craziness
