Tekin RS ESC sensored
need some help here, I run a rs speedo, 1 cell lipo,tq booster,fantom 17.5 motor,and a 9650 servo,all hooked together by a sr 3500 rec. in a gen xl.
last nite I got it all placed in the car nice and neat,and turned the switch on,and nothing happened,no pt lite,no lite in the rec,and no lites on the rs,lipo was fully charged,booster was instaled corectly.
than I hooked the rs up to the hotwire,and no lites came on.so im thinking the speedo died in my pit box,(worked fine 5 months ago)
now the ? is does the batt power go thru the esc first,than the rec?
im trying to pinpoint which part is bad. any answers.
check the servo wire make sure its not broke or cut
ok will do
Dear Tekin,
Please take my name off of you’re website and anything else you might use it for. I did not give you permission to use my name for any type of advertising. I did not put anything down on my sponsorship sheet nor did they announce the type of speed controller I was using.
Thank you,
Kelly Bean
Thank you,
Kelly Bean
Now that I have that off my chest, could someone answer my simple question? Is V198 with timing set to zero the same (performance wise) as v208?
No crap given on my end. He requested to have his name removed and we abliged.
Sponsorship is earned not simply given.
Randy - You have mail.
Dear Tekin,
Thank you,
Kelly Bean
Thank you,
Kelly Bean
Can we get of the subject,he was upset about something and it is resolved
Hey guys
I am starting to race 1/12th scale
I will be using a 1S lipo and booster , is there any known problems with this set up ??
and how do i make my RS novice friendly in my 1/12th scale ??
i will be running 13.5 SP motor in it with a high grip 30m straight track
Thanks again fellas
Thanks again fellas
Wow... lots of drama
Heck took second in the 17.5 TC A main at the IIC... feel free to use my name if you like.. I ran a Tekin and aint ashamed to let everyone know
Randy sent you a PM with the info if you care to use it
Hey guys
Thanks again fellas
Thanks again fellas
