Tekin RS ESC sensored
#1652
Unfortunately when it comes down to it you can't add more timing to sensorless mode.
Without giving too much away it becomes an issue with how the technology of reading the rotor postion vs. timing advance that is the issue. We can do more advancement in sensored only since those are used as the input rather than other feedback methods.
#1653
Yep already asked Jim if he could do that (a while ago) and that's the reply I got.
#1654
Hotwire V 189
Hey guys,
Where can I get the new 189 version ?
Have tried updating the ESC but latest version I can get is 180
Any help would be great
#1655
Hi i have a problem.
First it was so we tought the sensor wire but after testing i found out that that is not the problem.
I have when i update reset en set my transmitter and esc ok that i have less power than i hath with the 183 software. After bracking and giving full trottle again i have a lot of power. i can do this several times and it goes great. but after 4 or 5 times it goes back to slow driving again. looks like half trotle.
after a few tries i get again full power.
and so on and so on.
Then i tried the dual mode. i get the same thing. same problems as i get sensord only.
When i down greade it again and rest it again and transmitter ... then i have again full power and i have no problems.
i tried several motors and al where the same.
What can be the problem?
i played with the timing and nottong helpt. I have those problems only in the 189 software.
can someone help me?
#1656
Please email me directly and we will send you a new unit. I want your unit back for testing here on our carpet track and get it on the scope to see what is happening.
Tekin Prez
#1657
i have sended you an E-mail bij rctech. is that the right mail adres?
greetings Emiel
greetings Emiel
#1658
So whats the word on this system any comments would be great I need a 17.5 system for my world gt class
#1659
#1661
#1662
I don't believe so. I think that's why people can't run 1S on a 1/12th scale car without a receiver pack. You need enough voltage to power the receiver to tell the esc what to do. Without a receiver pack and only running 1S, the BEC won't kick in since the voltage from the main pack is too low.
#1663
Josh does need a receiver pack, but it's because his particular receiver needs more than the 4.2 volts his single cell LiPO is putting out.
Josh... that 4.22 reading is at rest, fresh off the charger. You might find some receivers that will run at that voltage, but after the car has been on for a short time the voltage of the battery will drop to the high to mid 3's. At that point any current receiver will get erratic or shut down.
#1665
any tips for setting up rspro with a 9.5? What do u guys recommend for gearing? i have 78 on my buggy(gv2).
