Tekin RS ESC sensored
#1621
just installed the 189 software. the boost feature is nice. i set it to max just to mess around with the tires up in the air and wow talk about some RPM. I am running a Speedpassion 13.5 in my TC so the timing is fixed at 0 degrees anybody running the boost feature have a suggestion and where to start with the boost?
Pull the rotor out and look at the sensor location. They should be near a slot. If they are centered in the slot it is set at 30deg. If it is left of the slot by 5, 10 or 15deg, that is how much less than 30deg it is. If it is really set at 0deg it will be 30deg to the left of the slot.
FYI our motor adjust from 0 to 24deg. So we adjust to 6deg short of the slot center for max timing.
We are finding that a total of motor physical timing and boost of about 30 to 40 is good. Up to 40 with lighter loads and the slower motors like 17.5 and closer to 30 or 35 in most cases.
THE EXTRA RPM REQUIRES REDUCING THE GEARING. If you are over the top it will be a missle for a few minutes and then fade off. Temps can skyrocket in the motor quickly when it fades. Like always start low and work back up.
Tekin Prez
#1622
Can someone tell me when exactly boost kicks in? Does it get activated at full throttle?
#1623
When you say use 30-40 for the boost do you mean set the slide bar on the Hotwire there, or set the Hotwire close to max and it equates to 30-40 degrees?
#1624
#1625
He said 30 - 40 total timing, so that's your motor's timing plus the boost setting. Funny enough I ended up with 39 degrees this week end without knowing about this...
#1626
-Wayne
#1627
Max setting is 30 degrees. I would always recommend timing the motor to the max and adding less timing boost just because I believe it's better to have most of the timing in hardware rather than software. saying that Tekin have done a great job on the software side.
#1628
I...
Pull the rotor out and look at the sensor location. They should be near a slot. If they are centered in the slot it is set at 30deg. If it is left of the slot by 5, 10 or 15deg, that is how much less than 30deg it is. If it is really set at 0deg it will be 30deg to the left of the slot....
Tekin Prez
Tekin Prez
#1629
#1630
Any ballpark ideas on where to run the boost on a Novak 13.5?
#1631
Is that with the boost software? I thought it was 45 total in the speedo with the boost. I tried setting the motor at max and speedo low and on a dyno and the power out put was 73 watts at a 25 amp load, when I went the other way the power out put was higher, 77 watts.
#1632
Once initialized you can move the trigger and see what signal we are seeing. If you see all 7 leds lit at half throttle the epa may be too high. If you see half throttle (4 leds) at full trigger the epa may be too low. If full trigger is close to full throttle we should accept it fine.
#1633
Ok guys well I have an small issues with a buddy's RS ESC. When I turn the car on all the led's light up really but are really dim. I tried downgrading the ESC to a older version then back up to the latest and it still does not work. If I hold the mode button when the 7 dim led's are on it will ramp up one time then go back to nothing. I also get an error message when I try to apply new settings on my hot wire. Any ideas?
Also make sure a button is not stuck down.
Tekin Prez.
#1634
I believe the max setting on the slider bar is 45 degrees. I run mine at max and the motor timing at 0. I used this setting with my 17.5 and 13.5 at the US Indoorchamps and had PLENTY of speed down the staright and LOTS of infield speed when geared properly. With that much timing with a 17.5 motor I had to gear it down to a 3.06" roll out on a large track. In 13.5 I was at 42-88 with 1.68" rear tires.
-Wayne
-Wayne
The sensor sees the magnet coming and triggers about 15deg before it actually gets there. This can vary with different motors, sensor sensitivity, rotor strength, rpm..... So it is hard to compare to motors and really ever have equal timing in sensored mode. In sensorless (dual mode) all motors have the same and accurate timing. That is why we still like sensorless for mod motors where timing changes can have big effects and it is critical for multi pole motor like we are using in 1/8 scale.
Forget the secret 15deg and set the TOTAL of motor physical timing and boost setting to 30 to 40, gear back and work back up.
#1635
The Novak only adjust to about 12 deg of timing. So add 18 boost to be at 30 total.
Feigao based motors typically adjust to 30deg of timing. When set at max they only need 10 boost to be 40 total. So maybe more like 5 boost for most setups.
Not sure where all the fixed timing motors are set.
Tekin motors adjust to 24deg of timing. You do the math
REDUCE GEARING WHEN ADDING BOOST!
