Tekin RS ESC sensored
ok guys, I'm having a strange problem with my RS. It will periodically completely shut down. Receiver and servo are down as well and it will just roll then power back up. I'm running a 17.5 in spec mode (this also happened in 203). A friend of mine suggested that I try a different sensor wire, but I can't see how that would completely power down my electronics. Any ideas are appreciated. Thanks--Al
It can be duplicated easily. Turn off the esc switch, and turn it back on. That's what's happening. So, check for loose connections at the rx plug from the esc. I had the exact same problem. All I had to do was crimp the metal plugs in the connector a little to make a tighter fit at the rx. Problem gone. If that doesn't help, you might have a short in one of the wires from the esc to the rx. No guarentees, but give it a try before spending money.
Just demoted my 'old and busted' HS-625 to steer my silvercan spec car.
I need a litle help(my friends would say I need alot), My Tekin w\v208 and when I had v203 after about a minute or so into a run the power drops off like I have no turbo at all. If I let the car sit for a minute the power comes back. My motor temp on a x12 13.5 is 135f+/-, and my speedo temp is 115f+\-. when I put it back on the computer the settings have NOT changed at all.
Antone have a solution to this problem?
Does the rs shut down completely? are you able to control the steering when the power drops off?
i would presume that is still on and you can.
Couple of things to check. Speedie plug into the receiver, if your like me and your an avid user pulling the plug out so many times can take its toll.
Make sure your capacitor is still attatched 100% though it might look like its still there the actual legs are a bit prone to snapping, don't ask me how but i have had this happen also.
best bet is to replace the cap.
if you using an x12 make sure you are running the 4 dot insert and its the right way around lol, sloping clockwise as you look at the back of the can. you may have done a sensor board also on the motor, try different sensor wires. whilst the motor isn't getting hot it might be masking something else. you may find that the motor is getting very hot very quick and then cooling down quiclky also.
Need help to sort out unit that ended up going WOT on me for 2-3 sec. with no steering control. Unit is being used in my 13.5 TC with 208 installed.
sounds like a reciever brown out to me.
Make sure you setup your failsafe on your transmitter/reciever properly.
are you using 2.4 or crystals?
Using 2.4 and fail safe set but with no power to rec.fail safe will not work.
Everything is working great with the Acer netbook! I do have a question about the set up sheet and what happens......
I tried Randy Pikes 2wd 9.5 set up tonight.....
His set up calls for...
THROTTLE PROFILE C1 I "accidentally" had THROTTLE PROFILE 3=Linear
His set up also calls for.....
TIMING PROFILE C1 I had TIMING PROFILE C1...with 95 timing advance 5400-20000
Did my ESC run in THROTTLE PROFILE 3 and Bypass my TIMING PROFILE of C1 because I did not have my THROTTLE PROFILE set to Custom?
Or.....are these two entirely different adjustments and why would it have a "CUSTOM" setting in the throttle profile???
Thanks Guys
Thanks Guys
Thanks Guys
Thanks Guys
Thanks for the help guys!
how do i get out of 208 i would like to go back down to 203. and does anyone have a 203 i can download.
