SERPENT 120
#511
I really would not worry about it too much. It is a condition of this tweak system. I tried running a FF07 tweak system on one of my 1/12th cars last year and found the same issue. The car would not tweak on my tweak station. After spending a lot of time on the tweak station before every run and never getting the bubble to center after tapping on the car while in the tweak station, I realized that even though the bubble would move around, the car never seemed tweaked on the track. I think that’s the nature of this system. Julius is correct. I would remove the side shock before adjusting the tweak as it will make for a more accurate adjustment. We always check the tweak from the rear of the car. We have found that it is more accurate and achieves better results. You will need to use a good tweak station to adjust from the rear of the car. We use the Unity Tool station. A little pricey but it’s the most accurate and is good for both 1/12th and WGT chassis
http://www.unitytool.com/Unity_Tools...ek_boards.html
#513
Mr.Blonde- Soon we will be at the Birds and not only will we do well, we will listen to TECHNO for 7 straight days...168 hours!!!
Check your PM's and get back to me when you have a chance...
Butter
Butter
#514
I agree with you there. Too much pressure makes the mid point a bit fuzzy and makes the adjustment more critical without changing anything else.
#515
@Butter: I don't wanna loose........... dang dang dang *lol*
#518
I'd check either Stormer or Ashford Hobby. Stormer had 3 S120s within the last 2 weeks, but they are gone now. I've heard that both of these shops should be getting their shipments this week.
#519
1/4 x 3/8 rear
1/8 x 5/16 front
#520
I noticed that Stormer has a good parts list but 80% of them are "on order" This seems to be the case with everyone I talk to about the car. I am all to familiar with hard to get parts as a Corally driver. This is most distressing knowing that parts support is going to be even more difficult for this car.
#522
Suspended
#523
We have kits and parts in stock and new shipments on the way. So i don't think there is going to be any problem with availability
Mr Granone, go ahead confident, you will enjoy the car
#524
#525
Suspended
