Team Magic E4 Thread >
Old 04-07-2008, 08:59 AM
  #946
nocif13's Avatar
[QUOTE=gansei;4332818]
My ESC(MK03) is 20g more heavier than LRP TC.
QUOTE]
its a quark ESC,?
nocif13 is offline
Old 04-07-2008, 09:13 AM
  #947
gansei's Avatar
[quote=nocif13;4332906]
QUOTE]
its a quark ESC,?
YES IT IS Quark!!
gansei is offline
Old 04-07-2008, 09:33 AM
  #948
nocif13's Avatar
good or not?
nocif13 is offline
Old 04-07-2008, 11:49 AM
  #949
gansei's Avatar
Originally Posted by nocif13
good or not?
i did not do enough test for Quark ESC.
I will use this ESC in this weekend (Korea National Race)
I will update it's review in later.
gansei is offline
Old 04-08-2008, 11:23 AM
  #950
Trader Rating: 20 (100%+)
Originally Posted by luic
In Rcshopping or Wolfhobbies, is possible, but is you like i talk with Spanish distributor tomorrow, because the friday he said me, the next week arrived more parts. Maybe it is better to buy a whole car, because you have all parts, new parts and spares.
In other hand, yesterday and today, i make more hours of testing, some work and others no, for me.
In first, the rear hubs (kfactory 1.5š), are a option to have, the car is more planted with 3š rear.
Now the anti-squat rear, work best, the car is more easy when brake, and have very good aceleration.
In front, the same, the car is good enter to the turns, have more steering, but with the rear most caught.
Definitely, for me, work best the HB stabilizers, front and rear, i feel the car more roll, is more round into the turn.
I use, HB springs, too, but this is more personal, the Lbs are the important thing.
There is one thing, which was not explained, in the front rear pivot block, the ball conector support seems to work slighty better, pointing up rather than put a 1 mm washer below ŋ...? .
Finally, i test the Marcos, 2š setup, and the word is "smooth" , but for me, the lap times are slowest, is possible my skills are not than good, i haved to change some things.
In front, i put a 1.4 stabilizer, and 1mm F - 1.5mm R, below pivot blocks.
In rear, ball conectors up and 0.5 below, and 1mm rear.
With this changes, for me, are 0.3 - 0.5s, faster lap, but i use Sorex 36, because is the control tyre, for races here, and i need to adjust the car to this tyre.
Well, with this setup i put the rear hubs 1.5š + 1.5š in pivot block, (3š in total), and put 2 mm below upper link, front and rear, and the car are more fast, the grip in the track are slighty best, too.
Is normal, one setup is not possible to work perfect all people, the driver, the track, the grip, ...are more factors, but this setup work good, and helped me, thank you very much.
I hope, help to others TM drivers.
Here a photos, with 5300 Nosram Lipo, and HB stabilizers fit front and rear.
Greetings Luis C.
Would you please put this on a set up sheet and post it.Thank you Doug Lemmons
Doug Lemmons is offline
Old 04-08-2008, 11:27 AM
  #951
British Menace's Avatar
OK. What do you think is the best Li-Po Battery, Esc. and Brushless Motor set-up for the E4 and which E4 to get?
I'm looking at running the car both indoors and out on Tarmac on Rubber tires!
I'm not sure what the new classes for the Brushless are but I was thinking of whatever the "stock" equivelent is.
Pardon my ignorence about electric and classes etc.
Thanks for the help.
Regards,
British Menace
British Menace is offline
Old 04-08-2008, 12:00 PM
  #952
GreaseMonkey's Avatar
My lightweight E4!!!
My LRP TC ESC is die!!
I dunno about there but here they weight the car with the body on. How much does your body weigh?
GreaseMonkey is offline
Old 04-08-2008, 12:55 PM
  #953
nocif13's Avatar
Regards,
British Menace
for mi
ESC feigao xenum 120A=speed passion GT
motor=9.5 SP ultrasporsman and 6.5 feigao by team PETIYO
NO LIPO IN FRANCE,5cell 1b4200 orion
nocif13 is offline
Old 04-08-2008, 01:01 PM
  #954
nocif13's Avatar
http://www.rctech.net/forum/showpost...98&postcount=7
nocif13 is offline
Old 04-08-2008, 02:41 PM
  #955
Doug Lemmons, ok no problem with permision of Marcos , tomorrow i write the setup sheet.
For me, the best combo for E4, Nosram ISTC, Nosram 3.0, and Nosram VTEC 4600, no Lipo here, but Nosram 5300 and 4.0, is more fast than the bests touring gas cars.
Greetings,Luis C.
luic is offline
Old 04-08-2008, 04:23 PM
  #956
Dan/Ultraline's Avatar
Regards,
British Menace
Hey Tony,
Give us a call at the shop, we have Both speedos and batteries or just check our site.
We have the latest Speed Passion Gts in-Stock.
Dan/Ultraline is offline
Old 04-09-2008, 06:11 AM
  #957
gansei's Avatar
Default Big Crash.
My E4 go die!! in last weekend.
Because My transmitter Li-po Battery. my E4 go to wall in high speed.
my chassis and upper deck was broken.
i rebuild my E4 in today.. and made E4 Rebirth Music Video
(PS: My Another Nickname is Bander)
http://www.youtube.com/watch?v=7VHm5D0EGow
gansei is offline
Old 04-09-2008, 11:38 AM
  #958
nocif13's Avatar
impressive
nocif13 is offline
Old 04-09-2008, 12:29 PM
  #959
Oh, sorry Gansey, good video-homenaje.
Well, this is the setup i use in base to Marcos Setup, i donīt take any responsability is your cars do not respond to your commands after having released
Greetings, Luis C.
File Type: pdf
luic is offline
Old 04-09-2008, 04:18 PM
  #960
Thank you Luis,I will give it a try this weekend,Doug Lemmons
