Team Magic E4 Thread
#196
It dosent look like 28mm foam tires would fit only 26mm am I correct.
#197
#201
Hi, does anyone know how many teeth are on the center belt?
john
john
#202
E4 tip
1. stebil interference with sus-arm
-> use 1mm washer.
2. front bumper support cause up-stop.
-> cut support
3. rear-arm interference with rear-hub
-> cut rear-hub diagonal line.
-> use 1mm washer.
-> cut support
#204
Good tips
#205
E4 Movie
E4 Movie in highway circuit (yellow body)
my rear wheel was broken. (it(tire) was used in Nitro car)
so E4 go unstable in back-straight.
E4, LRT TC, Novak 3.5 brushless, gear ratio 8.67:1
sweep grip, No warmer, Mush-More 32 tire,
Much-More Slient Charger, Much-More 4500 NI-MH Battery (6 cells)
http://www.youtube.com/watch?v=yyf8wPnFIkQ
#206
K Factory
new E4 optional parts
TC Motor Cooling Head & Thermal Pad E4 Alum
#207
I've just finished builing my E4, and I was pretty impressed with the ease at which it went together, just one little concern, the centre belt is pretty tight. I expected a little bit of extra resistance in the drive train over my previous car, but this feels excessive, anyone else had a prob with this?
#208
