Team Magic E4 Thread >
Old 03-03-2008 | 02:13 AM
  #751
quickdik's Avatar
Originally Posted by yyhayyim
The E4 is real nice. not bad for its first outing
Race Proven please...
quickdik is offline
Old 03-03-2008 | 04:58 AM
  #752
Marcos.J's Avatar
Super Moderator
So far so good!
Marcos.J is offline
Old 03-03-2008 | 04:59 AM
  #753
Marcos.J's Avatar
Super Moderator
good , bring it with you on saturday
Marcos.J is offline
Old 03-03-2008 | 07:32 AM
  #754
yyhayyim's Avatar
I might have to roll in with something else---check your PM
yyhayyim is offline
Old 03-03-2008 | 11:32 AM
  #755
Default Brushless into the E4 RS
Hi,
I'm in need of some help and advice installing brushless motors into the E4. I'm in the middle of getting my new E4 prep'd for the test track and I'm struggling to get the Orion Vortex brushless motor installed. This is very very tight and doesn't give any movement for gear ratio's and little movement just to mesh it properly. Am I doing something wrong? Also, if the Orion is a known issue, can anyone recommend other makes that do fit, Speed Passion or Novak's ???
I love the car, but need to get it running 10.5 brushless !!
Appreciate anyone's help,
Jason
Moggers is offline
Old 03-03-2008 | 11:38 AM
  #756
Marcos.J's Avatar
Super Moderator
Originally Posted by Moggers
Hi,
Jason
You will have to take out the side brace and the side brace where the belt tensioner is then the motor will slide in. Also if you want to run 10.5 brushless you will need about a 75t 48 pitch spur or a 100 64pitch, you will need to get an assorment of spur gears to play with different gear ratios due to the tight space, but it doesnt take that long to change spurs and pinions. I posted some pics a few post back that shows some spots that you can take some material out to have a little more room to move the motor.
Marcos.J is offline
Old 03-03-2008 | 11:39 AM
  #757
Marcos.J's Avatar
Super Moderator
here they are
Marcos.J is offline
Old 03-03-2008 | 11:52 AM
  #758
Marcos.J's Avatar
Super Moderator
I also have my spare chassis modified to use the Pro 4 /cyclone front arms After I broke a front arm yesterday i needed a solution didnt get to finish it at the track but i will this week. I ended up using CA and pieces of papertowel's and it held up for 2 qualifiers and a hefty battle in the A-main
Im going to test this out but its mainly for a back up plan if i get in the same trouble again Im still using the E4 arms
Shock and sway bar mounts are 99.9% in the same spots.
Marcos.J is offline
Old 03-03-2008 | 01:40 PM
  #759
Marcos.J..........what you don't know about this chassis ain't worth knowing about !! Thanks very much for all your input to this forum.
Have you tried the Speed Passion 10.5 or 13.5 in this car ? I'm assuming the issue will be exactly the same?
Anyone recommend a better 13.5 or 10.5 brushless than the Orion ?
Cheers,
Jason
Moggers is offline
Old 03-03-2008 | 02:21 PM
  #760
Marcos.J's Avatar
Super Moderator
Cheers,
Jason
lol
I only run Speedpassion motors , I used Orion before it will be the same, you will have linited room for motor movement so like i said just get an assorment of spurs and you will be fine.
I highly recommend the Speedpassion motors they are fast!! ( as long as you get the Speedpassion ESC too,so you can really tune the motor!!)
It only takes me about 2 minutes to completely change motors and spur. It'll be worth it
Marcos.J is offline
Old 03-03-2008 | 02:34 PM
  #761
nocif13's Avatar
Hi,
Jason
http://teammagice4.blogspot.com/2008...lantation.html
nocif13 is offline
Old 03-03-2008 | 02:42 PM
  #762
nocif13's Avatar
HI MARCOS
What changes did you do to ADJUST THE the Pro 4 /cyclone front arms ?
THANK
olivier
nocif13 is offline
Old 03-03-2008 | 02:46 PM
  #763
Dan/Ultraline's Avatar
Thanks for the link
Dan/Ultraline is offline
  #764
Marcos.J's Avatar
Super Moderator
Originally Posted by nocif13
HI MARCOS
THANK
olivier
well i had to take some material out of the arm towards the back to be able to get the exact wheelbase and i also had to ream out the arm to be able to use the E4 caster block. Then I added the shims shown on the picture to allign every thing as the E4 arm. I also had to use a shorter cvd bone 46mm to fit. I havent ran it yet I really dont know the benefit , like i sai i got cought in a jam over the weekend (broke and arm and had no replacement) so i had to do this modification but i ended up just gluing the arm and adding some papertowel (like fiberglass body work on a car).
I have no idea about the outcome i just needed something to finish the race for the weekend
Marcos.J is offline
Old 03-03-2008 | 02:47 PM
  #765
Marcos.J's Avatar
Super Moderator
Originally Posted by UltraLineMotors
Thanks for the link
good link I was going to post the pictures of mine but he did the same thing that I did
Marcos.J is offline
