FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF
#1262
#1263
Based on the FF-04 thread and Kentech's blog there is the suggestion it lacks 0.5s+ a lap compared to more conventional layouts. I'll soon find out if this is true...
#1265
We keep playing with my sons setup on his BE FF04 Evo, trying to move both front and rear arms further forward. Not sure if it is possible lower the motor further given the location of the suspension mounts? Who knows perhaps a 3D printed test setup may work. We have even tried the SMC Lowrider 21.5T motor in an attempt to relieve some of the front axle sprung weight.
#1266
#1270
I think TCR will need a brass chassis first... Mine is 210g too light for FWD racing ;-)
#1272
Brass won't work for a chassis. But spring steel might...... Chassis material doesn't give you flexibility with CG location.
#1274
Belts have fewer places to lose energy. Each belt or gear interface nets a 1-3% loss in torque. So long as the belt doesn't have high hysteresis, you're gonna be in better shape with a belt than a triple gear transmission.
Motor rotation direction could a tuning choice though.
#1275
What about gear ratios? Would it be easier to gear a belt rather than a all gear from internal ratios?
