FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF >
Like Tree678Likes
Old 08-04-2011, 04:44 PM
  #376
on small tracks its hard to keep up with the 4wd, but on a large track with fast corners its almost equal, the 4wd will still be a little faster but its not by much
Bappe is offline
Old 08-05-2011, 06:31 AM
  #377
In California we have been running the FWD's in our own class. The rules we have adopted are, Cirtix 17.5 ESC and motor, Actual FWD bodies, Any manufacturer (we have TOP Sabre's running against FF03's mostly) Tires and gearing are open. The racing has been very close with most cars finishing on the same lap.
Dragarcher is offline
Old 08-05-2011, 07:52 AM
  #378
Calamari100's Avatar
Smile
Hello,
I've got a Tamiya FF-02 chassis, and I've got some super grippy tires on it, but I can't seem to avoid front wheelspin during acceleration and turning. Is there anything I can do setup wise to alleviate this?
Thanks!
Calamari100 is offline
Old 08-05-2011, 09:19 AM
  #379
niznai's Avatar
Originally Posted by Calamari100
Hello,
Thanks!
Yes. The FF02 has way too much suspension travel. You need stiffer springs and some spacers inside the shocks to reduce suspension travel.
If the shocks are stock.
A good idea is to increase the viscosity of your shock oil, perhaps go 60 or 80 (80 front 60 rear woudl be a good starting point with the 1 hole pistons).
niznai is offline
Old 08-24-2011, 08:45 PM
  #380
akura2's Avatar
Does anyone have any info on this hopped up Yokomo YRF2... I LOVE my YRF2, and I want to be able to fid out what this person did to theirs and with what parts.... Thanks
I see it has 21mm rears, drilled out rear arms... VCS shocks in the rear and some weird single spring setup up front... but I don't read japanese... meh
akura2 is offline
Old 08-24-2011, 09:05 PM
  #381
akura2's Avatar
Originally Posted by akura2
I should have mentioned that I'm not looking to spend $100-$177 on a body...
LOL
Also.. I'm looking for the one that came out before the Martini... the all red Alfa
this guy has 10 in stock.. but he's asking $89 each for them
they are re-releasing these!!!... I've seen it on Tower and Horizon for under $30 ($27.99)
I am a happy camper!!!!
akura2 is offline
Old 08-25-2011, 12:57 AM
  #382
niznai's Avatar
Can you post a link. Can't see very well what's going on in those little pictures.
The single spring front suspension with no damper is the standard setup of "normal" YR-F2 cars. The dual front shock suspension is on the carbon version.
niznai is offline
Old 08-25-2011, 03:28 PM
  #383
akura2's Avatar
Here's a link to the picture
http://www.gaz-on.net/galerie/albums...o_yr-f2_80.gif
I have a YRF2 Special edition (with the dual front and rear shocks) that I've been running... I LOVE it
akura2 is offline
Old 08-25-2011, 03:52 PM
  #384
akura2's Avatar
The only problem I'm having with it now is that the rear end is skipping around in turns... I went from NiMh to LiPo and I think the weight is too light... I've added weight to the battery tray area toward the rear to make it equivalent to the battery I replaced (I have a brass battery tray weight from my Hot Bodies Cyclone TC http://www.amainhobbies.com/product_...ets-Cyclone-TC) but I haven't ried it yet... hopefully that will fix it
akura2 is offline
Old 08-28-2011, 07:43 PM
  #385
akura2's Avatar
I tested my YRF2 with the added weight and the handling REALLY woke up.... Here's my FF01 Nissan Primera special edition:
akura2 is offline
Old 08-30-2011, 07:03 PM
  #386
hopndrop's Avatar
Nice primera!
hopndrop is offline
Old 08-31-2011, 08:53 AM
  #387
akura2's Avatar
Originally Posted by hopndrop
Nice primera!
Thanks.. if it wasn't a collector car I would cut the 'smokestacks' though (I never leave more than one hole above the body)
I haven't searched to see where I could get replacements yet but as soon as I do, I'm cuttin' them
I"m getting the Alfa Romeo 155 DTM so after that body arrives and I check where the posts have to be, then I'm going to cut the posts to accomodate both bodies....
akura2 is offline
Old 11-25-2011, 01:45 AM
  #388
hopndrop's Avatar
ttt for the fwd's
hopndrop is offline
Old 12-24-2011, 12:32 AM
  #389
Default yrf2 special edition
anyone interested
http://www.rctech.net/forum/r-c-item...pecial-ed.html
boybawang is offline
Old 12-29-2011, 02:32 PM
  #390
UrabusDenis's Avatar
Hello FWD guys!
Just to make it clear, a Tamiya Peugeot 306 Maxi body will fit normally in a 190 mm 4WD TC and a Tamiya Renault Clio will not?
UrabusDenis is offline
