CRC 1/10 Pan Car
#1831
Anyone know of a carbon battery tray? I am converting my Pro10 to a WGT car, and dont want to buy the new chassis. But, I was thinking, if their was a flat carbon battery tray the same thickness as the chassis, then my battery could tape to it, and it would give me a flat chassis for my electronics to sit on. (I have no intention of removing it. )
Shawn.
Shawn.
#1832
Shawn.
Shawn.
I have never seen a flat carbon battery tray for the Pro chassis.
I would go with the LE conversion because its chassis plate is narrower than the Pro and does not drag through corners...a significant improvement over the Pro chassis.
Ampdraw.com does have the LE Conversion Kit for only $64.89.
Bill
#1833
I believe LOSI made a Graphite Battery Tray for their TC that also fits the GenX10. It has battery slots for Nimh.
#1834
#1835
#1836
#1837
Does anyone know if the 1759 - Pre-formed foam bumper for Gen-X 10 & Battle Axe will fit onto the LE bumper? The bumper on my LE is shaped differently (No Transponder Mount Hole) and I think the actual body mount post holes may be in a slightly different location? Any help is greatly appreciated. Thanks!
Justin
Justin
#1838
Justin
Justin
If not, you might indicate the dimension of how far apart the post holes are from each other and how far back they are from the imaginary line between the two side screws that hold the bumper to the chassis. Hope that is clear...LOL
Bill
#1839
Logic tells me that everyone would be guessing because you have not said where the bumper came from. If it is a CRC bumper, I suggest you contact John at CRC. His e-mail address is [email protected]
Bill
Bill
Justin
#1840
If those body post holes are 3" apart (c-to-c) and .95" (c-to-c) in front of the two side holes that mount it to the chassis plate; then, they line up with the standard front bumper.
You just have the one extra hole in the location where the transponder normally goes and the four cutouts are configured differently.
#1841
i went to a rubber/foam shop brought a couple pieces of closed cell of cuts for $2 (yep im cheap)
made my own bumper,maybe a little heavier and not as pretty but you can shape them to fit the front of the body better (more protection).
punch 2 holes so it slides over the body posts and use body clips to hold it down
#1842
#1844
transponder
works just about any where, i have mine monunted on top of the servo ,so im always giving people a 150mm start. Works fine.
#1845
Hi All,
I've recently got a 1/10 pan car with some electronics moved from my touring. Hopefully can outrun some nitro heads on a asphalt club track with long straights
Need some advises on the followings, please help me out .
1. What is the appropriate roll out for 4.5T on SP ESC with 2S
2. What is the right diameter on both front and rear tires
- I got a set of Xceed pan car tires and trimmed down from 64 to 59mm. Rim seems abit large that only got 5mm foams remain. The rear ride height is now 7.5mm with the most upper adjuster installed, should I down size the tires ? Still runnable with foams less than 5mm on asphalts ?
Thx in advance
Thx in advance
