Tamiya mini cooper
Most of the high speed wander goes away with more toe out. I find that when it starts to look like you have way too much, the car starts to settle down. There also seems to be a very fine line between enough and not enough tow out. If I take a half degree out of my car, it gets ugly on the straight even with the Tamiya steering linkage. Give it a try.
I'm thinking of getting a M05 to race in the spec class here (no upgrades allowed besides tires, and bearings). Was wondering what is a good servo to get?
I raced my M03 last season with the Futabu S3003 and it worked ok, just wondering if I should get something faster....
I use a Futaba 51 low profile. It's perfect.
For optional diff set ref --> 54194...What is the reference to replace the center screw? and the spring?
Spring: 9949299
TAM9949299
http://www.speedtechrc.com/store/ebp...id=615&id=5349
Diff Bolt: 49350
TAM49350
http://www.speedtechrc.com/store/ebp...id=894&id=6586
Outdrive blades: 53890
TAM53890
http://www.speedtechrc.com/store/ebp...id=615&id=5940
Well thanks for all your help. The response has been overwhelming.
diff
Tried a ball diff but prefer the Tam gear diff that comes with M05 kit, pack it with FG diff grease.
Took it out to see how its wearing and it is still like new.
FG diff grease is very sticky and helps stop wheel spin with one lifts off in corners, a bit like a spool.
New to Tam minis and still have touring EP cars, but not race them for over three months now.
Having too much fun racing Minis .
bodymot,
How does the car differ in handling when using thicker grease in the diff compared to standard Tam light grease?
Is the grease's part # Z-FG06512?
Thanks for your help mate.
ATB
Chris
ATB
Chris
Diff grease
Also because the diff gears are not spinning so much it helps the gears from over heating and wearing out.
I am only allowed to run Tam black can and silver can type motors where I race so don’t know if it would work with a lower turn motor.
I just found I had more speed coming out of corners.
hope this helps
just order some more for a mate from WHEELSPIN MODELS UK
FG 6512
I have been looking over the Mo5ra manual and can somone tell me the basic difference between the mo5 and the mo5ra. I see where there are skid plates and motor covers is there any thing else that is a major difference?
How long are the shocks compared to the Mo5?
any info would be really appreciated
oops my bad
i should read propperly before jumping in LOL
Ok read loads from other sites. Thanks for the Aus link. Very good but, i cant find anything about the ride height. Do you set it level or lower at the rear etc? Cheers
Anyone ever used a GWS S11FH servo on their mini? What's your opinion about that servo?
does the M05 kit have the servo horn to fit GWS servo spline?
