Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-11-2009, 11:43 AM
  #8521
ChattyMatty's Avatar
Default to retain pins
I use a little drop of old fasioned white glue (or RC 56). Holds for ever, until you don't want it to. Just push the pin through with a small screwdriver and the most if not all the glue comes right off with it.
ChattyMatty is offline
  #8522
Hyde's Avatar
you could use a hppy knife to trim the hex's a little around the edges. just so it doesn't stay in the wheel.
i run the tamiya metal hex's and there's never been a problem. there only 5 bucks too.
but the plastic ones are good. but if you hit or over tighten they will split causing the hex to rub the bearing
Hyde is offline
Old 03-11-2009, 12:55 PM
  #8523
MD
MD's Avatar
Trader Rating: 136 (100%+)
One of the guys at HPI that I know told me it probably would not be released in the U.S. I had heard March or April from the customer service at HPI. So, I emailed him and asked about the Cup Racer and he told me it would over $200. I told him that's out of my price range and asked him about the cost of FWD mini. And, he told me it probably would not be released in the U.S. I don't know or understand why, but that's what he said. May be he's wrong.
MD is offline
Old 03-11-2009, 01:31 PM
  #8524
The version they were displaying was the 4wd Mini. Interesting car. And I could be wrong too. Just repeated what the HPI people with the car were saying.
Granpa is offline
Old 03-11-2009, 01:37 PM
  #8525
tony gray's Avatar
The Australian HPI distributors displayed the same lack of knowledge about the Switch when questioned yesterday too. They'd never heard of it.
So I think we can safely assume it isn't on their agenda either.
So...ours are coming straight from Japan - easy.
tony gray is offline
Old 03-11-2009, 05:31 PM
  #8526
R/C Tech Elite Member
monkeyracing's Avatar
So...will there be a separate HPI Switch thread started, or will it get smooshed into this one?
monkeyracing is offline
Old 03-11-2009, 06:01 PM
  #8527
tony gray's Avatar
Already is one Jim, but I reckon it'd be best kept in here given that the same people would be interested in both..
Old 03-12-2009, 08:55 AM
  #8528
Zdiddy's Avatar
Hey guys, I have a couple questions for the mini experts. First off, what all wheels will work with the 60D tires (and that are TCS legal). I'm looking for part numbers on them as well as the part numbers for the aluminum shock kit and the sway bar kit, but I am having no luck. Any help would be greatly appreciated.
Zdiddy is offline
Old 03-12-2009, 09:41 AM
  #8529
Regional Moderator
Darkseid's Avatar
If the HPI cars take off like people seem to hope they will, I doubt their dedicated runners will want to have to come to the Tamiya mini cooper thread to talk about their HPI car.
Darkseid is offline
Old 03-12-2009, 01:51 PM
  #8530
tony gray's Avatar
Hmmm, given that HPI in the US (and here in Aus too) are denying any knowledge of the car at all I cant see them 'taking off' at all!
Old 03-12-2009, 04:22 PM
  #8531
Nah, I'm a hardcore Tamiya mini driving nut, and I'm hoping others are, too.
How dare HPI dilute our genepool with this.....thing!
Of course, none of that means that I still don't want one.
Jim
Old 03-12-2009, 05:36 PM
  #8532
Hyde's Avatar
i have soft compound HPI x-pattern tires all around my mini. i made home-made cool little tiight track. the front tires are glued but the rear seems to push out a little like a "little" drift.
i swear by these tires.
what would cure or fix this problems by adjusting the susp' any advice?
i use 3racing shocks stock black spings. about 1mm droop. its an m03r so i use the extra camber setting in the rear upright. [lower hole]
thanks for any input
P.s. tony!!! its tech racing.... that's what i use to have. i found a site that has many pics and specs of the rear end. thanks for the input tony. without the keywords "tech racing" i would've never found the rear end
Hyde is offline
Old 03-12-2009, 05:45 PM
  #8533
I used these tyres before too. But they seem to wear a little too quickly for me. Esp the front!
stocker is offline
Old 03-12-2009, 06:03 PM
  #8534
Hyde's Avatar
wearing out to quickly?!?! are you kidding??!!
any advice?
Hyde is offline
Old 03-12-2009, 06:09 PM
  #8535
See what happens if you either soften or raise the rear suspension a little. I'd go with softer first.
Jim
